m1sterb0b
Thanks for the picture dstout, I'm pretty sure mine looks quite similar. My dad and I are going to pick up a replacement at a junk yard hopefully.
As for you being able to replace the control module apart from the actual abs module, yes, you can. The mechanic that checked it said there are several parts you can service yourself, the control module being one of them. He said that, if you really wanted to, you could replace the little motors inside of the abs module that control which brake gets how much power etc . . . I just need to get the parts and replace it. A junk yard will probably sell the control module with the abs module, most places don't find it worth-it to remove them from each other. Most people usually replace the whole unit anyways.
