Thread: And they say it can't be done?
Results 1 to 20 of 31
  1. #1 And they say it can't be done?
    Banned
    Wichita Falls, Texas
    So, on more than one occasion I've had people say we're stuck with the stock back brakes, and all that can be changed is the rotors and lines. So I figured it's about time someone documents proof that those people have no idea what they're talking about.
    Does that rear caliper look stock to you?
    What about the front one? That doesn't look like it came off of an F-Body.
  2. #2 Re: And they say it can't be done?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    So those rears are Fbody? What year group? Dual piston? Size?
  3. #3 Re: And they say it can't be done?
    Oklahoma
    I tell you that, God as my witness, if you dont spill the beans Im going to walk down to Wichita Falls and hunt you down and torture you until you do.
    Those look to be aluminum, correct? What modifications were required to get those calipers to work? Come on man, you got to give us more information, LOL.
  4. #4 Re: And they say it can't be done?
    Banned
    Info coming tomorrow.
  5. #5 Re: And they say it can't be done?
    Las Cruces, NM
    Not dual piston, I can tell that.
    Not vented either.
    Grand Am rears always worked but that's a known mod. I hope it'd not that.
  6. #6 Re: And they say it can't be done?
    PA
    Its tomorrow. I know...I'm impatient!
    2001 GSE
  7. #7 Re: And they say it can't be done?
    Jan 1970
    Maquoketa, Iowa
    wake up! It's information day!
  8. #8 Re: And they say it can't be done?
    Oklahoma
    I put this over in brakes and handling since it seems to be more centered around that.
  9. #9 Re: And they say it can't be done?
    That looks just like my Grand AM rears...saves 1.5Lbs over stock.
    fronts save about 16-17#
  10. #10 Re: And they say it can't be done?
    Las Cruces, NM
    Yeah...that's what I was thinking last night. Saves weight but it's not an upgradein braking power.
  11. #11 Re: And they say it can't be done?
    Oklahoma
    So, which brakes do I need to get for both front and back. 16-17#'s is quite a bit to save up front. I want these brakes, just tell me the model and year and Im makin a trip.
  12. #12 Re: And they say it can't be done?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    yeah they do look like GA calipers...
    so you save weight, but no real increase in brake force, i dont think.
  13. #13 Re: And they say it can't be done?
    PA
    Quote Originally Posted by Toasty View Post
    I don't know what streetwolf has up his sleeve. But I do know that Ron is running Grand Am brakes in the front, if not the back. Yes, he saves weight. But I don't think there is much improvement in stopping power. About the same as stock GP brakes I think. I know he said he hasn't had any problems with them. But I chose not to take off my stock brakes, and replace them with something equivalent only for weight savings. I want to be able to stop when I want to, so I will be upgrading to larger brakes.
    2001 GSE
  14. #14 Re: And they say it can't be done?
    Oklahoma
    I will, in a heart beat, switch out my brakes just to loose some weight and I wouldn't think twice about it. Ive never had any problem stopping and the GP brakes have never given me reason to question their performance. So while I wouldn't turn my nose to more braking force, I wouldnt do so either at a reduction in weight, even if that was all I got out of the deal.
  15. #15 Re: And they say it can't be done?
    2000+ Grand AMs, you need the calipers, rotor, and banjo bolts for the fronts.
    The bracket is a direct fit with Grand Am bolts and sleeves, or you can drill/tap them for the GP bolts M14 by 1.0 pitch IIRC.
    The backs use the same rotr and pads as the front, but you have to shave a bit off the back of the caliper to allow correct brake line adjustment. I have a write up on CGP.
  16. #16 Re: And they say it can't be done?
    SW Chicago Suburbs
    Quote Originally Posted by Ron Vogel View Post
    I'd reccomend to get the brackets tapped, not use the sleeves... seems a number of people with the f-body brakes have experienced losening caliper bolts with the sleves... though i suppose it could be due to not using new loctite or similar....
  17. #17 Re: And they say it can't be done?
    Oklahoma
    Ron, could you perhaps PM me the link to the write up on cgp? And would you mind if I host it here as well?
  18. #18 Re: And they say it can't be done?
    I don't know PM's on here, but this is the link. I don't care about it going on here.
    (ClubGP Message Forum troubleshooting)
  19. #19 Re: And they say it can't be done?
    Banned
    Sorry it's taken so long to post a reply. I've been busy with the Land Rover at the lake all day.
    Lucky for me though Ron seems to have covered about everything there is to know.
    Yes, they are Grand Am front and rear brakes, with cross drilled/slotted rotors, and stainless steel brake lines. As Ron already posted the sole purpose for doing this upgrade, yes upgrade, is for weight savings. They stop just as good as the stock brakes, and even better than stock with the stainless lines added, as to be expected.
    By the way, for those that hadn't noticed. This is not my car, I run the F-body brake setup on the front and have something of my own in the works for rear rotors and calipers.
  20. #20 Re: And they say it can't be done?
    Las Cruces, NM
    Upgrade?
    These are known to be used as a RACE ONLY braking setup because the rotors are thinner than the GP rotors and will warp quicker than GP rotors.
    Please someone post side by side pics of the front rotors with the view looking at the cooling fin areas so you can see the thickness of the surface area and cooling fins.
