I'm sure this has been discussed and I did a search but I didn't find what I'm looking for. I have a 96 SE coupe and the rear sags bad on it and it will rub the left rear tire over dips in the road and bumps. Not really worried about the rubbing but it just looks silly..
My question is, what can I do to return the rear back to factory ride height? I have replaced both struts which helped the rubbing but not the sagging. Is there anything I can personally do aside from bringing it to the dealer to have the rear spring replaced? If I'm not mistaken it has a mono leaf spring and requires a special tool to remove. I have tools out the a$$ but nothing for removing the rear leaf of a GP. Is there a helper spring available, perhaps a spacer or rubber isolator? TIA
