Thread: Looking to drop the nose more...
Results 1 to 20 of 22
  1. #1 Looking to drop the nose more...
    SE Level Member SilverToy's Avatar
    Jul 2010
    Fort Worth
    OK, I have the Eibach springs and AGX's. Now I want to drop the nose another 3/4 inch to level it out. What are some suggestions? I like the way it feels, I just don't like the droopy diaper look!
  2. #2 Re: Looking to drop the nose more...
    only choices you have are B&G springs or intrax springs. intrax are gonna slam it.
  3. #3 Re: Looking to drop the nose more...
    Charles City, IA
    Take the dead hookers out of the trunk, Or get new springs, sounds like yours are worn out in back. Unless you have a lot of weight in the trunk.
    SMGPFC Two Nipple General
  4. #4 Re: Looking to drop the nose more...
    Jul 2010
    Fort Worth
    Trunk is empty, I dumped the hookers, and the shocks and springs are new. It settled out with the fronts about 3/4 inches higher than the rears. I like the height of the rears that is why I'm trying to figure out a way, short of new springs, to drop the nose a bit.
  5. #5 Re: Looking to drop the nose more...
    Ocala, FL
    Seems like some springs are just lower in the rear, right out of the box.
  6. #6 Re: Looking to drop the nose more...
    Kansas
    measure from ground to top of wheel well and see if its really off.
    SOLD 1999 GT Silvermist TS
  7. #7 Re: Looking to drop the nose more...
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    got any pictures?
    btw where can we get intrax springs?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  8. #8 Re: Looking to drop the nose more...
  9. #9 Re: Looking to drop the nose more...
    I live here. TLSheff's Avatar
    the internet.
    You Sir Just made my day, thats got WIN all over it
  10. #10 Re: Looking to drop the nose more...
    Dec 2008
    Lawndale, CA
    I don't recommend this but it is an option. You could remove the front rubber isolators and get some heater hose and wrap the bottom most coil. That will drop the front a little more. Some guy on club gp did it. F body guys do it as well when lowering the rear on stock springs and call it the heater hose mod.
  11. #11 Re: Looking to drop the nose more...
    Jul 2010
    Fort Worth
    Thanks Guz, that's a interesting one to look in to. All ideas are welcome!
  12. #12 Re: Looking to drop the nose more...
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    coil overs are the way I am going it makes your suspension completely adjustable.
  13. #13 Re: Looking to drop the nose more...
    Jul 2010
    Fort Worth
    I don’t want to get off subject but Yep, they are the way to go, not sure which coil-over's your looking at but I love my TEIN FLEX coil-over's on my other toy and always highly recommend them, I just don't want to put that much in my GP as it's really my daily driver.
  14. #14 Re: Looking to drop the nose more...
    If you get coilovers i'd suggest taking them off for the winter if you drive it all year round.
  15. #15 Re: Looking to drop the nose more...
    nah thats too much work and its not that cold where im at. I am curious why you would suggest doing it though?
  16. #16 Re: Looking to drop the nose more...
    the coilovers on your 'other' toy are way different. the coilovers for these cars, only one brand to choose from, reduce your strut travel the lower you go and eventually youll run out of room to lower it if youre into the dumping scene.
    however, i dont agree with matt. i would adjust them up a little higher before the snow hits. youll then need two alignments a year to do it right. however, the salt and winter wear will probably end up seizing the locking rings.
  17. #17 Re: Looking to drop the nose more...
    Coilovers arent tolerant to dirt and such so having snow packed in there for a while doesnt end well.
    My boss's subie has coilovers and he's been fine but he's so anal about his car he cleans his coilovers regularly in the winter.
    Thats my point. Unless you clean them. But who needs to be low in the winter?
  18. #18 Re: Looking to drop the nose more...
    Jul 2010
    Fort Worth
    Thanks for the info Bio248, I'v never looked at coil-overs for the GP, I did not know the selection was that limited.
  19. #19 Re: Looking to drop the nose more...
    they do not thread into the lower body like your tein flex' do. you dont lose travel no matter how low you go, which is why i enjoy those types of coilovers.
  20. #20 Re: Looking to drop the nose more...
    Theres a guy on OQCGP that has made a custom strut mount which allows for more travel... goes by the name weirdo
  1. s/c nose drive
    By Royalblue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2010, 11:28 AM
  2. squeaking nose from steering
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2010, 08:09 AM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
