Thread: What spare tire (doughnut) to use with 12" brake upgrade?
Results 1 to 18 of 18
  1. #1 What spare tire (doughnut) to use with 12" brake upgrade?
    Feb 2008
    I used the search and couldn't find anything that addressed this question. I have done the 12" front brake upgrade and now the stock spare tire (doughnut) will not fit on the front. I remember hearing/reading somewhere about a spare tire (doughnut) that would fit. Does anybody know which one will work?
    Thanks folks.
  2. #2 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by Blown97 View Post
    Thanks folks.
    Could grab one out of a 00-05 Impala or Monte from a junk yard. Those cars have 12" brakes stock and I can assure you my doughnut fits the front.
    2009 Subaru Impreza WRX STI
  3. #3 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Feb 2008
    Quote Originally Posted by Sabrewings View Post
    Awesome!! Thanks Sabre!
  4. #4 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    In reality, though, you should never put the spare on the drive wheels anyway. Move one up from the rear and put the spare on there. Our diffs are weak enough as it is, putting the donut on there is just asking for trouble.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by Scimmia View Post
    You could do a mean one wheel burnout with the doughnut for sure.
  6. #6 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    May 2008
    staten island,NY
    x2 on swapping the rear tire to the front. or just keep a tire plug kit in the trunk saved my ass a few times
  7. #7 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by QwikGT View Post
    Tire plug kits ruin the tire. Plugs are never as good as a decent patch. Just throw the spare on and take the tire to a tire shop for a $25 patch and be on your way.
  8. #8 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    GTP Level Member dstout's Avatar
    ky
    Almost every tire shop here use plugs and not patches. I don't know why.
  9. #9 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Charles City, IA
    Plugs really have no place in car tires unless they are used in conjunction with a patch.
    SMGPFC Two Nipple General
  10. #10 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    TDCRacing
    Guest
    Good info in this post. Keep it up fellas.
  11. #11 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Odessa, MO
    Ditto on what he said.
  12. #12 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Barksdale AFB, LA
    Quote Originally Posted by dstout View Post
    I've never seen a legitimate tire shop (Firestone, Gateway, etc) use plugs. My friend who used to work for one said they're forbidden by their home offices from using plugs.
  13. #13 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    ky
    I guess they didn't get the memo here cause everybody plugs tires.
  14. #14 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    memphis
    Plugging tires is a quick & eazy(lazy) way for tire shops to fix a flat. A patch is a much better fix. you never hear of a patch popping out.
  15. #15 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    SE Level Member dementedDALEK's Avatar
    CANADA
    You could always do what I did when I blew one of my front tires and discovered that I didn't even have a spare in the trunk - call a tow truck!
  16. #16 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    MA
    Bonnie GXP or DTS spares will work too..
  17. #17 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    canada
    as for me I would go through the trouble of moving a rear to the front and using the spare on the rear, much safer driving that way
  18. #18 Re: What spare tire (doughnut) to use with 12" brake upgrade?
    Charles City, IA
    holy old thread batman....,but yeah spare in the back good tire in front.
  1. Brake Upgrade
    By bct717 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2009, 10:21 PM
  2. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  3. Spare tire well
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-25-2008, 10:08 AM
