Just put cross drilled rotors and semi-metallic pads on my car (got them as a kit, otherwise I would have gotten ceramic) The cadmium plating has worn off the contact area of the rotor(which I knew would happen) and now the brakes sqeual like all get out. I am assuming it is cause of the pads. My question is will it do this until the pads wear out or will this eventually go away. Supposedly the pads gaurantee no sweak...wrong!
