Thread: Squeaking sound coming from rear wheel
Results 1 to 5 of 5
  1. #1 Squeaking sound coming from rear wheel
    Fargo, ND
    02 GT. I don't know if I can technically call it a "squeak", but it has something to do with the rear driver side wheel. With every rotation of the wheel, I can hear a sound, like a bearing is out or something. At first I thought it was a warped brake rotor, so I changed pads and rotors on the rear of the car, but the sound is still there.
    Anyone have any ideas? Bad hub maybe?
  2. #2 Re: Squeaking sound coming from rear wheel
    Omaha, NE
    Could be a wheel bearing, a wheel out of balance, bad alignment, tire rubbing on a trailing arm...
    I would jack the car up and see if I can replicate the sound so that you can diagnose it that way.
  3. #3 Re: Squeaking sound coming from rear wheel
    Cambridge, Ontario Canada
    Take a look at the strut mount too, sounds more like a bushing though
    2005 E55 - stock
  4. #4 Re: Squeaking sound coming from rear wheel
    Fargo, ND
    So I think I may have narrowed down my search a little bit. Decided to put engage the parking brake today, and then disengage it. Well, to my amazement, the squeek disappeared for a couple minutes, but then it started back up again. I stopped, but the parking brake on again, took it off again, and once again, the sound was gone for a couple minutes, but it comes right back.
    So what do you guys think, something wrong with my parking brake?
  5. #5 Re: Squeaking sound coming from rear wheel
    i had the same problem with my regal, you just have to back off the e brake, its inside the rear brake rotor, works just like old drum brakes, turn the star wheel till it no longer makes noise.
  1. Clunking sound coming from driverside wheel well
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 08:01 AM
  2. Weird sound coming from belts
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 10:48 PM
  3. paper flapping sound coming from the rear manifold
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2010, 12:35 AM
  4. * * Rear End is SQueaking & Sounds Bad ( BUSHINGS? ) * *
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 10:44 AM
  5. squeaking sound?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 05:35 PM
