Thread: brake booster vacuum problem
Results 1 to 13 of 13
  1. #1 brake booster vacuum problem
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    Well I just recently got done putting the new motor in and now the car idles really rough. The map sensor jumps from 35-65 KPa. I noticed that my brakes also felt as though there was no brake booster connected to them. Anyways I found that when I caped the nipple on the supercharger that goes to the vacuum line to the brake booster, the car's idle smoothes out and map reading stabilizes around 45 Kpa. The vacuum line has no leak and the attachment lets air pass. I am thinking it has something to do with the brake booster ruining my vacuum pressure. Do I need a new one, or am I forgetting another vacuum line or something. If it needs to be replaced, is there a rebuild kit for it?
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  2. #2 Re: brake booster vacuum problem
    take a picture. the thing on the top of the blower should have all the lines filled. here, look at mine:
    there is one that goes to the BBV, one that goes to the brake booster, and another that im not sure where it goes to, but i can check it a little later if need be.
  3. #3 Re: brake booster vacuum problem
    Barksdale AFB, LA
    Does there really need to be two threads on this?
    2009 Subaru Impreza WRX STI
  4. #4 Re: brake booster vacuum problem
  5. #5 Re: brake booster vacuum problem
    Jan 2009
    Gainesville, Fl
    well not everyone checks each category everyday as some people are better with other subjects. This is a brake issue and an engine issue, so yes it feel lit belongs in two categories. the third bio saw was a question to 02blue. The vacuum lines are ran just like yours bio, and I followed the diagram. Like i said its the brake booster thats messing the pressure up when connected to the supercharger via vacuum hose.
    -1996 Acura TL
  6. #6 Re: brake booster vacuum problem
    Barksdale AFB, LA
    The problem with posting in multiple sections is there's a lot of cross talk between the threads that makes it confusing.
    And yes, plenty people browse every section.
  7. #7 Re: brake booster vacuum problem
    Jan 2009
    Gainesville, Fl
    Quote Originally Posted by Sabrewings View Post
    it cant hurt to get more input though
    -1996 Acura TL
  8. #8 Re: brake booster vacuum problem
    Jan 2009
    Gainesville, Fl
    doe any one know how to diagnose a brake booster once its off?
    -1996 Acura TL
  9. #9 Re: brake booster vacuum problem
    Jan 2009
    Gainesville, Fl
    Well i took off the brake booster and tested it with my hand. There seems to be no pressure being held, and the back of it looks like it is not sealing as well. This car is almost worst then my fbody as far as everything breaking.
    -1996 Acura TL
  10. #10 Re: brake booster vacuum problem
    Nov 2008
    Chicago
    I wish i had never sold my fbody and done a top swap on that *****. Sorry to hear about your brake booster.
    Not to steal the thread but I didnt see much point in making a new one while we where on the subject. The brakes on my GP take ALOT more foot pressure than most cars. If I put my foot on the pedal and start the car, the pedal sinks. If i let the brake go, shut off the car, and press down, the pedal is the same way until i start pumping it of course. So with that little test out of the way, is this normal?
  11. #11 Re: brake booster vacuum problem
    Jersey
    Quote Originally Posted by FuglyGTP View Post
    yeah thats what mine does.
    16' wrx sti- stock
  12. #12 Re: brake booster vacuum problem
    Jan 2009
    Gainesville, Fl
    that actually was the exact test to validate a working brake booster when i looked it up. lol... mine didnt sink and look at me now.
    -1996 Acura TL
  13. #13 Re: brake booster vacuum problem
    Nov 2008
    Chicago
    That test is one of the few things that i remember from HS auto's class. Dont forget to check your check valve!
  1. How much octane booster?
    By Sabrewings in forum General Tech Discussion
    Last Post: 08-18-2009, 11:19 PM
  2. Antilock Brake Problem
    By $03gp/gt$ in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2009, 05:33 PM
  3. Brake Booster? Who has changed one?
    By sra_chipmunk in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2008, 07:24 PM
  4. Booster
    By SJ95GTLQ1 in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2008, 10:38 PM
  5. Octane booster
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 02:04 PM
