Earlier this year I bought a used 2000 GTP Coupe (red of course with a tan interior) in really nice cosmetic shape. Even with 100K on the clock it seemed in OK mechanical shape, especially the motor. Soon thereafter I had to replace the trans and that started me on a modification kick. Since buying it I've concentrated on the suspension mostly since the stock motor is very, very potent for a 6 cylinder, especially when working through a good tranny. I kept my stock springs, installed KYB AGX struts, 12" StopTech front rotors with Hawk full ceramic pads, Stoptech rear rotors with ceramic pads, new powder coated NHT calipers, Addco front and rear sway bars, GMPP trailing arms and new mounting plates, front GMPP tower brace and to top it off, a Corsa cat back system. Since that time (10K miles so far) I've reached the following conclusions:
1. Exhaust. If noise is an issue at all Corsa is the way to go. All other systems are far louder than Corsa, especially in the area of resonance. I originally installed an SLP cat back system with a large resonator. I was not happy at all with how the car sounded inside. Outside...fantastic. Inside...ugh.
2. Brakes. The brakes are the best I've ever had on any car bar none!!! The combination of upgrading to a 12" front rotor, StopTech rotors and Hawk ceramic pads is a complete success. I'd recommend it to anyone.
3. Sway Bars. Started by finding out the ends of my stock bar were rusting through and breaking. Had an older model Addco front bar, but it would not fit. I contacted them and at no charge sent me a new front bar. Fit perfectly. The rear however is a different story. The bar fits well enough but does not have the same shape as the stock sway bar and comes VERY close to the Y-bend of the Corsa. Had to jury-rig an exhaust mount to prevent them from coming into contact. It works but I had jury rigging anything. The most frustrating thing was trying to get the cooperation of other sway bar manufacturers in determining which bars may fit better. They just didn't seem very interested in helping.
4. Struts. This is the real reason for this email. I use my car to commute daily 40 miles one way from Severna Park, MD to the Pentagon. The roads in the DC area are some of the roughest I've ever driven on. The KYB AGX shocks are NOT the right choice and although I've only got 10K on them I want to go back to a more compliant strut. However, I want the best quality, most long wearing strut I can find. What do you guys (and gals) recommend? Should I go with all new stock GM replacement struts? Should I go to non-adjustable KYB? Gabriel? Monroe? Koni? I'm not going for low price but instead the best quality and performance. What do you recommend?
