Thread: Rear STB only...
Results 1 to 17 of 17
  1. #1 Rear STB only...
    GT Level Member a3gtp's Avatar
    Feb 2009
    Salter Path, NC
    I have the opportunity to buy a rear strut tower brace for a very good deal.
    I currently don't have a front one. Will there be any benefit from buying this and installing it? I plan on eventually buying a front one also but for now will the car still handle good with just the rear.
    BTW the car is a 97 GTP around 275+ whp
  2. #2 Re: Rear STB only...
    TDCRacing
    Guest
    You won't be able to tell any difference with the front and the rear more than likley.
    But if it's a good deal go for it.
  3. #3 Re: Rear STB only...
    Barksdale AFB, LA
    The rear makes the biggest difference of the two. The front only a small difference. Buy it.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Rear STB only...
    Feb 2009
    Salter Path, NC
    So I can run just the rear for now? I'll buy it I just wanted to make sure the car would would retain handling with just a rear stb.
  5. #5 Re: Rear STB only...
  6. #6 Re: Rear STB only...
    Barksdale AFB, LA
    Quote Originally Posted by a3gtp View Post
    Some actually prefer only the rear to both. You might too.
  7. #7 Re: Rear STB only...
    Feb 2009
    Salter Path, NC
    Ok thanks for the quick responses. I'm gonna go buy it for 25 bucks
  8. #8 Re: Rear STB only...
    St. Louis Mo.
    You will definitely feel a difference in how tight the rear feels when cornering or if you are turning a corner that has a curb or hump in it. The car will feel more solid when going over it. It wont feel like its flexing a much as compared to one without.
    I am running both a front and rear Speedbuilt STB and I lovem to death!
    The only word of caution I mention is avoid just drilling into the strut tower to secure the brace. I would get Don Rome's brackets to add to the STB to allow them to hook upto the strut tower bolts. It will make it a lot more secure in the long run
    James Shafer
    St. Louis MO
  9. #9 Re: Rear STB only...
    Aug 2008
    KCMO
    whats the difference in the speedbuilt and the gm ones?
  10. #10 Re: Rear STB only...
    a couple pounds in weight. i bet they do about the same amount of good though.
  11. #11 Re: Rear STB only...
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Are there any vehicles that have stock ones that would fit on a 2002 gt?
  12. #12 Re: Rear STB only...
    Barksdale AFB, LA
    Quote Originally Posted by WhiteGT View Post
    Any w-body.
  13. #13 Re: Rear STB only...
    May 2008
    Ontario
    Quote Originally Posted by Sabrewings View Post
    Any w-body.
    Any specific models that came stock with them? I was looking at a 2000 regal sc that had one but I noticed that my strut towers don't have the same studs that it bolted to. I would prefere one that bolts on to the strut mount bolts.
  14. #14 Re: Rear STB only...
    Barksdale AFB, LA
    None came stock like that, so you won't find any at a junk yard. 00-03 Impalas and Montes had the front STB stock. But you would need to either drill into your strut towers (not desirable) or get the brackets to add them without drilling.
    Here's a picture of the brackets. DonRome makes them:
    Front:
    Rear:
  15. #15 Re: Rear STB only...
    May 2008
    Ontario
    So even with the brackets you still have to drill into the towers, the bracket would just add strenght then right?
  16. #16 Re: Rear STB only...
    Barksdale AFB, LA
    No, the brackets make it so you don't have to drill. They go onto two of the strut mount studs (on each strut), and then the STB bolts to the brackets.
  17. #17 Re: Rear STB only...
    May 2008
    Ontario
    Oh Ok, the pics make it look as if the bolts go through the bracket and into the top of the strut tower. Thanks.
  1. Rear End Roar
    By bshinos in forum General Tech Discussion
    Last Post: 11-30-2010, 01:52 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
  4. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
