Thread: Abs/trac off
Results 1 to 4 of 4
  1. #1 Abs/trac off
    Michigan
    Right front harness broke in half so I soldered both wires back together but the lights are still on. What should my next move be? The car is an 07 gt
  2. #2 Re: Abs/trac off
    St. Louis
    Test the plug for voltage with a meter. With the key on you should see 4.8V or so. If not, then your wire is bad somewhere else down the line. Just went through this on my 00 GT. If the harness checks out then meter the 2 leads in the wheel bearing. Jack that side up and put it in neutral, chock the rear tires. Set meter to millivolts. At rest you should get 0, and then have someone spin the tire. You should see some voltage show up on the meter. If this does nothing then you have a bad hub and will have to replace it.
    Also, check all your fuses and make sure none are blown. Should be the underhood and inside the car. Worst case save up some $$ and have it scanned at a dealer or shop that can read the ABS codes, as the scanners at most parts stores will not read these cars. Need a GM Tech II usually. That will tell you exactly which wheel is having an issue. Post the code here and we can help further.
  3. #3 Re: Abs/trac off
    Michigan
    Quote Originally Posted by FordMan77 View Post
    Ill have to troubleshoot on Sunday and see what I come up with. Thanks for the advice
  4. #4 Re: Abs/trac off
    Sep 2012
    Ottawa, Ontario
    This is how I used the first option (doing the brake thing) but since your car is newer, it may have a different reset method.
    How to Reset the Sensor for an ABS on a Pontiac Grand Prix | eHow.com
  1. ABS/Low Trac
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 10:32 AM
  2. ABS/Trac Off!!! HELP!
    By Hawkins97 in forum General Tech Discussion
    Last Post: 09-11-2011, 11:43 PM
  3. TRAC Off
    By tdm571 in forum General Tech Discussion
    Last Post: 12-28-2010, 02:22 PM
  4. Trac off?
    By trigun87 in forum General Tech Discussion
    Last Post: 05-23-2010, 12:14 PM
  5. No ABS or Trac
    By Hamsalad2 in forum General Tech Discussion
    Last Post: 04-06-2010, 03:00 PM
