Thread: Front Upgraded sway bar hitting.....
Results 1 to 2 of 2
  1. #1 Re: Front Upgraded sway bar hitting.....
    Feb 2009
    VA
    Quote Originally Posted by Lion29GTP View Post
    i installed the new upgraded sway bar on my 98 GTP and it's hitting the down pipe when it is in drive, it vibrates the floor. Should i switch the bar left to right?
    It should be flipped over itself. I've been told to start at the passenger side and pick the bar up (with it off the car of course) with the driver side stationary (fulcrum point), push it over so the passenger side is now the driver side and reinstall. The "v" of the bar should be facing away from the downpipe.
    Hopefully that made sense. It's been a while since I did it.
  2. #2 Update:Re: Front Upgraded sway bar hitting.....
    Jan 2009
    Long Island
    Thank you very much for help.
    I finally got it on a lift to look at it properly and it's amazing how much of a difference at lift is. The bar was upside down ( "v" was inverted and was hitting).
    Correct it and feels smoother
  1. front sway bar
    By Toasty in forum General Tech Discussion
    Last Post: 03-23-2013, 12:34 PM
  2. 04+ front and rear sway bar upgrade
    By 04CompG in forum General Tech Discussion
    Last Post: 10-17-2008, 03:29 PM
  3. 04+ aftermarket front sway bar
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2008, 03:54 PM
