Thread: Clunk/pop noise on accelerating/braking no one can diagnose
Results 1 to 6 of 6
  1. #1 Clunk/pop noise on accelerating/braking no one can diagnose
    May 2013
    Chesapeake, VA
    Hey guys, my 03 SE has been driving me crazy with a noise on moderate acceleration from a stop and moderate to hard braking, noise seems to come from drivers side front. No noise turning, on bumps, no vibration.
    New parts I installed in last 2 months:
    Front padS (Bendix), rotors (AC Delco)
    Lower mounts (trans/engine)
    Struts (Moog sent back due to noise on bumps, Monroe installed nice and quiet on bumps)
    Drivers side cv axle
    Previously about year ago installed performance upper dog bone inserts for less engine movement and new sway bar bushings
    Few years back: upper and lower control arms with ball joints and bushings
    Still clunking
    2 shops have told me nothing loose etc to cause this
    I did notice play between lug studs and rotor, I have a video but have to figure how to convert file from mp4 to attach.
    Car has just surpassed 300k and is good daily driver but this noise has got me stumped, any help appreciated!
  2. #2 Re: Clunk/pop noise on accelerating/braking no one can diagnose
    May 2013
    Chesapeake, VA
    Here is the video i promised, is this normal? Maybe source of my noise.
    2003 Pontiac Grand Prix Clunk - YouTube
  3. #3 Re: Clunk/pop noise on accelerating/braking no one can diagnose
    all rotors do that the wheel makes it all tight.
    check your motor mounts. pop the hood, then fire it up and watch the engine when you shift from p to r then to D. the engines is going to bounce a bit, but if it moves like 2 inches the lower mounts are dead. engine mount tends to let the engine even slide forward and back on the belt side of the bay.
  4. #4 Re: Clunk/pop noise on accelerating/braking no one can diagnose
    HUDSON
    Check your subframe bushing to body mount bolts, make sure they are tight. Also, check rack and pinion mount bolts, and lower control arm mount bolts. All these places gave me clunks at one time or another.
    Cracks in the subframe can cause clunks but not common, unless car was in a crash at one point in its life.
  5. #5 Re: Clunk/pop noise on accelerating/braking no one can diagnose
    May 2013
    Chesapeake, VA
    Ever since I put those red inserts from ZZ Performance in the upper mounts, engine movement has calmed down quite a bit plus lower mount is solid now not hydraulic. Thanks for info on rotors, I couldn't figure that being a problem considering AC Delco parts. I'll check sub-frame and other parts Quicksilver mentioned. Gonna check torque on lug nuts too. Thanks for input guys.
  6. #6 Re: Clutightennk/pop noise on accelerating/braking no one can diagnose
    pa
    Quote Originally Posted by 2003GrandPrixSE View Post
    I had a similiar noise, the metal brace that is above the air box in the engine compartment was loose. the noise was a random creaking noise. good luck
  1. solved
    By NFSCano in forum General Grand Prix Discussion
    Last Post: 08-20-2016, 10:21 AM
  2. Get a Clunk sound when accelerating
    By IronShot in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2015, 05:09 AM
  3. Help Diagnose my clunk
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2014, 05:53 AM
  4. please help me diagnose this noise *videos*
    By jdmgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2010, 10:51 PM
  5. Clunk when coming to stop and/or accelerating
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 05:43 PM
