Thread: Front sway bar
Results 1 to 10 of 10
  1. #1 Front sway bar
    Jul 2020
    Abbotsford, BC
    Well, I had the crap startled outta me a few days ago. I was turning, coming out of a parking lot at low speeds (<10mph) and there was a loud BANG THUMP THUD CLUNK CLUNK from the front of the car.
    I immediately pulled over in the next parking lot but didn't see anything obviously broken under the car. I went home and occasionally there was a clunking sound from the front of the car. (I mean occasionally. I tried to reproduce it by going over bumps, hard braking, etc and couldn't get it to do it.
    I drove it home and parked it, and during that drive no noise.
    Drove it to work the next morning and it made a clunking noise occasionally. Didn't seem to matter if I was driving on a flat road, turning etc.
    So I parked it and finally today crawled under there and did an inspection.
    The sway bar snapped in two! That kind of explains the godawful loud noise when it happened.
    Long story short - should I just go to RockAuto and try to find a replacement or should I look around and see if there's an upgraded bar available? 1997 GTP.
  2. #2 Re: Front sway bar
    May 2020
    Pittsburgh
    ZZP sells an upgraded bar or two.
  3. Likes danf liked this post
  4. #3 Re: Front sway bar
    GT Level Member mguzzo's Avatar
    Buffalo NY
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. Likes danf liked this post
  6. #4 Re: Front sway bar
    Jul 2020
    Abbotsford, BC
    Thanks, I'll see if I can find a GMPP bar. The local parts place can get the OEM one if I can't find one around here.
  7. #5 Re: Front sway bar
    Buffalo NY
    the link I gave is for a GMPP bar. if you do both front and rear you'll get a ni8ce improvement in handling overall.
  8. #6 Re: Front sway bar
    Jul 2020
    Abbotsford, BC
    The shipping was more than the cost of the bar, but thankfully the local GM dealer was able to get it for about $170 CAD. After exchange, that's only $50 above the exchange rate and I don't have to pay extra shipping to get it here. That's a miracle, usually parts here are double or sometimes triple what you pay in the US.
  9. #7 Re: Front sway bar
    Jul 2020
    Abbotsford, BC
    When searching for the rear bar, I came up with 12498642, does anyone know if that's the correct PN#?
  10. #8 Re: Front sway bar
    Buffalo NY
  11. Likes danf liked this post
  12. #9 Re: Front sway bar
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by danf View Post
    if the oem bar is hollow, you might want to consider returning it and getting a solid one. after the ends finally gave out on mine, i replaced it with a dorman. tightened the front end up quite a bit
    08 grand prix NA3800
  13. #10 Re: Front sway bar
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    Walk into your local junk yard and there is probably a Dorman one on a W-Body that you can pick up dirt cheap.
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  14. Likes tomsteve liked this post
  1. Broken front sway & alignment ? Also sway bar recommendations..
    By Exile in forum General Tech Discussion
    Last Post: 10-14-2016, 12:24 PM
  2. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
  3. 04+ Front Sway Bar
    By MidnightBlue in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2012, 07:35 AM
  4. Front Sway Bar
    By 1SICKGP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:20 PM
