Thread: No fluid from right rear brake line
Results 1 to 3 of 3
  1. #1 No fluid from right rear brake line
    St. Louis
    Had the owner of the 01 GT come over today so he could help me bleed the brakes. Backstory, I had to remove the 4 lines from the top of the ABS module in order to install a new fuel line (feed side). Nothing is leaking fluid anywhere.
    Started at the right rear as usual and noticed I wasn't getting anything. Pulled the banjo bolt and cleaned it out. Still nothing. Left the line off the caliper and had him press the pedal gently. Nothing more than a drop or 2. For a test I undid the left rear and repeated. Fluid shot out like it should.
    Installed a new brake hose on the right rear and STILL nothing more than a drop. I'm not sure what else could cause this other than maybe the aluminum proportioning valve that is right before the brake hose on that side.
    Anyone else have a better idea before I replace that valve?
    So much for a 1 hour brake bleed....
  2. #2 Re: No fluid from right rear brake line
    Apr 2014
    commerce twp,mi
    on a different make and model, i had this problem. someone much smarter than me on brakes said bleed the fronts. that can help to reset the valve. it worked on that one.
    sometimes hammering the brake pedal a jillion times helps.
    sometimes gravity bleeding can help.
    08 grand prix NA3800
  3. #3 Re: No fluid from right rear brake line
    St. Louis
    Well, I can always try the fronts first and go from there.
  1. rear brake line question
    By 01pontgp in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2019, 07:10 AM
  2. brake line blew across rear frame
    By pontiacgt500 in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2016, 11:28 AM
  3. rear brake line setup on 00 GT
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 05-21-2016, 10:05 PM
  4. No brake fluid to rear calipers
    By South Central in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2013, 08:20 PM
  5. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
