Thread: Tie Rod Question
Results 1 to 7 of 7
  1. #1 Tie Rod Question
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    When getting an alignment today. I was told my driver's side tie rod was frozen, and so I need to replace all four tie rods.
    Is it possible to replace just the ends, or so I actually have to do all four rods?
  2. #2 Re: Tie Rod Question
    GT Level Member mguzzo's Avatar
    Buffalo NY
    generally it means just replacing the ends because the ball joint at the end siezes up. it's not hard to do in the driveway. You need to loosen the jam nut, count the number of turns to take the old one off, screw the new one on the same number of turns, and tighten the jam nut. Then get an alignment.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Tie Rod Question
    Apr 2014
    commerce twp,mi
    if one is frozen i dont know why theyd say all 4 have to be replaced. however, i prefer to change both outers at the same time.
    08 grand prix NA3800
  4. #4 Re: Tie Rod Question
    Jul 2016
    Brevard County, FL
    I imagine it's a combination of "change both sides at the same time" and "make more money."
  5. #5 Re: Tie Rod Question
    Jul 2016
    Brevard County, FL
    Are the tie rod ends the same on all 04-08 Grand Prixs, or does the GXP have special ones?
  6. #6 Re: Tie Rod Question
    Nov 2019
    WI
    Quote Originally Posted by Hurricane87 View Post
    They're the same as a regular GP. TIP: instead of counting threads, loosen the jamb nut and then snug it back up to the tie rod just enough so that you can still remove the tie rod end. I did this on mine and didn't need an alignment afterwards.
  7. #7 Re: Tie Rod Question
    Nov 2019
    WI
    I used ac delco ends.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
