Thread: difference between gxp front brakes and impala police
Results 1 to 4 of 4
  1. #1 difference between gxp front brakes and impala police
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Are gxp and impala police brakes the same size? I have seen multiple threads that say they both have 12.7" rotors and then others that say the gxp is 323mm and the impala has 303mm. Can anyone clarify?
  2. #2 Re: difference between gxp front brakes and impala police
    Impala brakes are smaller than GXP brakes.
    302.8 for Impala and 323 for GXP.
    If you want solid front rotors for the GXP you need front brakes for a Buick Allure/LaCrosse (super) with the 5.3 V8 engine. They are the same 323mm with non drilled rotors. The AC Delco part number is 18A2414.
    You can probably find rotors at a NAPA store too if you went that route.
  3. #3 Re: difference between gxp front brakes and impala police
    Sep 2018
    NC
    would those calipers and brackets from the Buick bolt right up to a GP?
  4. #4 Re: difference between gxp front brakes and impala police
    Maybe.
    You'll need to do your own homework there. Look at rockauto and start cross referencing part numbers to see what might be the same.
    Or go to a store and ask to see a caliper for a GXP and a caliper for a Buick.
  1. 2004 police impala
    By SgtMarshal in forum PCM Tuning
    Last Post: 12-28-2014, 05:49 PM
  2. 06+ Impala front brakes in and done!
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 09-06-2013, 09:27 AM
  3. 06+ impala front brakes
    By usetaboost in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 08:42 PM
  4. Impala Police Package Upgrades
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 05-02-2010, 03:18 PM
