Thread: 2006 GXP struts/springs upgraded?
Results 1 to 7 of 7
  1. #1 2006 GXP struts/springs upgraded?
    Nov 2018
    OH
    I know these cars haven’t been made in a while, were all the replacement parts discontinued too? I can’t find anyone that makes a lowering spring or even a strut/spring oem replacement. I found $1,000 coil overs, but not looking for that. Am I just looking in the wrong place? Everything says exc. 18” wheels.
    Thanks
    Chris
  2. #2 Re: 2006 GXP struts/springs upgraded?
    Kemmerer, Wyoming
    you can swap over to 97-03 style and then use those lowering springs. personally I'd just be happy with the springs that came stock with the car. I have a 2001 and a 2008 and in stock form the 2008 is just as good as my 2001 with upgraded struts and springs.
  3. #3 Re: 2006 GXP struts/springs upgraded?
    Nov 2018
    OH
    Interesting, so the 97-03 retrofit? With the V8, doesn’t that have some added weight. What the problem is, the car is sitting 1/2-3/4 lower on passenger side. I’m assuming the spring was changed at one time or it simply wore out? Anyway, I am even having an issue just trying to find a “stock” strut/coil assembly for a GXP. They all state for 16 or 17” wheel only.
  4. #4 Re: 2006 GXP struts/springs upgraded?
    Kemmerer, Wyoming
    here's some oem struts, then you would just need to find oem springs which shouldn't be too hard.
    2008 PONTIAC GRAND PRIX 5.3L V8 Strut | RockAuto
    edit: scroll to the bottom of the list and select the yellow struts, they are the bilsteins that you want
  5. #5 Re: 2006 GXP struts/springs upgraded?
    Nov 2018
    OH
    Thanks for the reply, I feel the springs are needing replaced as well bc of the height difference. I can’t see paying $1000 for struts/springs to put on a $5,000 car. At this point I’d probably just go with whatever I can get away with.
  6. #6 Re: 2006 GXP struts/springs upgraded?
    Think about this, people add aftermarket wheels all the time to cars.
    People stop caring about what a specific part says it fits because it simple does not matter most of the time. The 18in rims that the GXP runs makes zero difference on what spring you can run or what struts. It's the offset of the wheel and tire size that matter, because that is going to cause the rubbing.
    I believe SSC or Canuck Motorsports still makes lower springs for the 04-08 cars. It used to always say the GXP specific springs were gone but the regular springs would still fit. They just lower the car less.
  7. #7 Re: 2006 GXP struts/springs upgraded?
    Nov 2018
    OH
    Interesting that you say that. I emailed Canuck and they have been great to reply. They said any Grand Prix spring would fit. Only issue...they are out of stock on all springs until 2019. I just want a 1.5 drop and not the 2.5 that GXP specific springs give anyway.
  1. 2006 GXP Struts to choose?
    By gtidd in forum General W body
    Last Post: 10-25-2014, 12:57 AM
  2. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  3. 2006 GT, time for new struts/shocks?
    By huttler in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 09:28 AM
  4. 04+ struts & springs
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-03-2009, 04:21 PM
