Thread: '99 Emergency Brake adjustment question
Results 1 to 5 of 5
  1. #1 '99 Emergency Brake adjustment question
    MD
    I'm trying to "tighten up" the emergency brake pads on my '99 with rear discs. Can someone please tell me what direction the "star wheel" has to be turned (UP or DOWN) for each side. If my memory serves me right, the driver's and passenger's side wheels turn in different directions to open the spreader wider.
    Thanks!
  2. #2 Re: '99 Emergency Brake adjustment question
    i take the brakes and rotor off and then adjust them. never had no luck using the hole in the backing plate.
  3. #3 Re: '99 Emergency Brake adjustment question
    MD
    Scottydoggs, I do have the caliper and rotor off. Not using the hole. But was just wondering which direction to turn each star wheel. I think I may have figured it out. Passenger side turns "up" to spread parking brake pads, so I assume driver's side must turn "down". Agree?
  4. #4 Re: '99 Emergency Brake adjustment question
    one might be reverse threads, as you turn it you can see the spreading. easy to figure out, open the pads a turn or so then test fit the rotor till its just lightly rubbing as you spin the rotor. if you go to far you cant get the rotor on past the e brake shoes.
  5. Likes jammy liked this post
  6. #5 Re: '99 Emergency Brake adjustment question
    It's real simple.. if it clicks nice when you turn it.. that's spreading the pad. If it's a brutal fight or you have to pull the tab to get it to turn.. that's compressing.
  7. Thanks jammy thanked for this post
  1. Emergency brake adjustment
    By markpa in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2016, 04:37 PM
  2. Emergency brake uses fluid?
    By TDgrand in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2013, 07:21 PM
  3. Emergency brake light always on
    By 99gtpguy in forum General Tech Discussion
    Last Post: 05-14-2013, 07:41 AM
  4. Remount Emergency Brake
    By 96GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2010, 09:50 PM
  5. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
