I can't car too good.
02-13-2018
There's pumps with and without reservoirs. Is that something hard to change over (ie. possibility of leaks)?
Also there's a few listed for an 05 GTP. Any brand/part number recommendations?
Thanks
#2
Re: Power Steering Pumps?
02-13-2018
pretty sure the tank and cap pull off the pump, just a o ring seal. lube it and push it in the new pump.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
02-13-2018
Thanks mein.
There's A-1 Cardone pumps on the cheap. Should I go Delco with this thing or what?
#4
02-13-2018
i only replaced mine once, like 8 years ago now. used a duralast one, its been working since. and its quiet, but most cant say that.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#5
Replaced with a cardone pump on a friend's car, it whines like hell from the minute the car starts and doesn't stop
Sent from my XT1710-02 using Tapatalk
#6
Went through 2 Cardone pumps. Both whined upon install. Junk. Installed AcDelco and zero noise. Night and day difference in rebuild quality. You have been warned! LOL. You may get lucky and get a quiet pump or you may get good and changing ps pumps if you don't like the whine.
04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
