Hey guys, so I've heard that you're supposed trim the bump-stops (rubber thing in bellow that slips over strut) on lowered cars, but I'm not sure how much to trim off. I'd say that for a 1.5 inch drop, they should be trimmed 1.5 inches, but I thought I'd check here first. Also, I'm using kyb bump-stops on Bilstein struts and the actual strut on the bilsteins are way thicker than the openings in the bump stops. so I've decided to bore out the hole so it'll fit. Anyone ever done that before? How did you do it? TIA
