Thread: what do i need to upgrade to 12 inch rotors?
Results 1 to 7 of 7
  1. #1 what do i need to upgrade to 12 inch rotors?
    Aug 2008
    Long Island, New York
    I was gonna do an fbody conversion on my car, but i decided it was too expensive for me to do right now when i would rather put more money into engine stuff and that i would just go with the 12 inch rotors. is there anything i need in order to convert to 12 inch rotors?
  2. #2 Re: what do i need to upgrade to 12 inch rotors?
    Jersey
    yes you will need 12" rotor caliper brackets.
    16' wrx sti- stock
  3. #3 Re: what do i need to upgrade to 12 inch rotors?
    Dec 2008
    Lawndale, CA
    As stated you will need the 12" caliper brackets. You can either get them from GM or find an 02 monte carlo or impala at the junkyard and take the entire front brake set up.
  4. #4 Re: what do i need to upgrade to 12 inch rotors?
    Barksdale AFB, LA
    Doesn't need to be an 02 Impala/Monte. All 00-05 Impalas/Montes use the same 12" brakes. Well, 05 had a slightly different hat to the rotor. But not even really worth mentioning. Still works and is interchangeable with the rest.
    2009 Subaru Impreza WRX STI
  5. #5 Re: what do i need to upgrade to 12 inch rotors?
    SE Level Member Berger's Avatar
    Feb 2008
    New Philadelphia, Ohio
    Just to make sure Im understanding this, all you need is the bracket? The calipers are the same?
    2003 Grand Prix SE / Redfire Metallic
    GT/GTP body conversion - 3"FWI - 56mm TB - AGX/SSC combo - 077's - GMPP front/rear sway bars - GMPP trailing arms - GMPP front/rear STB with DR brackets - 03 Limited Edition spoiler - 12" Front Brakes
  6. #6 Re: what do i need to upgrade to 12 inch rotors?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Yes, everything else is exactly the same, all you need is the brackets and the rotors themselves.
    2001 Buick Regal LS - Almost Stock
  7. #7 Re: what do i need to upgrade to 12 inch rotors?
    Feb 2008
    thanks
  1. 20 inch rims questions
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 09:32 AM
  2. 20 inch rim help
    By mzendano in forum Tires & Wheels
    Last Post: 01-10-2009, 02:48 PM
  3. What would i have to do to safely run a 3.0 inch pulley?
    By John_Shughart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2008, 02:56 PM
