Thread: ABS Hum
Results 1 to 2 of 2
  1. #1 ABS Hum
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Every time I move my car after its been off awhile I get this hum noise that sounds like it is in front of the steering wheel. It happens after I put the car in gear and a few seconds after it starts moving. It sounds like a weak abs hum.
    Is this normal?
    Is it some kind of ABS system check?
    I don't have abs lights or anything else happen. It seems like my old gp did this too only the trac light would come on.
  2. #2 Re: ABS Hum
    abs self test, sounds like a dragging rake or a crunch sound. if you touch the brake pedal, like ride it a little bit you can feel it in the pedal.
