Thread: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
Results 1 to 9 of 9
  1. #1 How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    Aug 2016
    Lethbridge, AB
    I need to order replacement parking brake cables but I'm seeing a variance in length based on which suspension package my particular car has, but I'm not entirely sure how to find that bit of info. My mechanic took the seized cables out about a month ago and likely tossed them, so I won't be able to measure the old ones.
  2. #2 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    open the trunk, on the under side is a sticker, its all the rpo codes.
  3. #3 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    Oct 2011
    Toledo, OH
    Well, FE4 is GXP only. 07GT would be supercharged right? So it wouldn't likely have the FE1 which go on the base models.
    7"
  4. #4 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    I bet the part number is exactly the same for each suspension package. GM is not that stupid, they wouldn't make 3 different parking brake cable lengths just because one has a different strut in it.
  5. #5 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    Oct 2011
    Toledo, OH
    There was 2 different part numbers and lengths when I bought mine, but I'm almost %100 sure the GXP/FE4 was the different one because I had FE2s and now FE3s and it was the same.
    7"
  6. #6 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    FE 1,FE 2, and FE 3 all have the same size. GXP is the one that is different
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  7. #7 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    Aug 2016
    Lethbridge, AB
    I opened the trunk but didn't see a single sticker anywhere.
    Quote Originally Posted by rickisrad View Post
    Awesome, thanks!
  8. #8 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    Sep 2015
    Cheyenne, WY
    Look under the trunk mat by the spare tire.
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  9. #9 Re: How to tell if my '07 GT has the FE1, FE2, or FE4 suspension package?
    hangover park IL
    gxp rear brakes have the "in hat" parking brake like the earlier cars. the CompG rears have the parking brake arm off the caliper.
    to put the gxp rears on my 04 comp G I had to swap on the early style rear knuckles and parking brake cables.
    cG had a "barrel" terminator on the cable for the caliper arm, the early/gxp cables have a loop that fits over the arm in the backing plate bottom.
    ~James~ Psychotic Gearhead
  1. Sub/Amp Package
    By DreadMcLaren in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2011, 12:16 AM
  2. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  3. 06 SE appearance package
    By romande in forum Visual/Body Modifications
    Last Post: 08-03-2008, 08:53 PM
