Hi everyone, I have a 2000 GTP with some rusty rear brake lines from being parked on the grass by the previous owner. Basically I would like input on how I should replace them because there are a few ways to do so. (I'm definitely doing the repair myself) Do the lines unbolt in just two places or are there clips that hold them in other spots underneath the subframe? Also do you recommend buying pre-bent lines or standard 1/4 inch lines that I bend myself? I was also considering running the new lines in a more convenient spot. Any and all input is greatly appreciated, thank you.
