Thread: GXP Brake Upgrade Questions
Results 1 to 5 of 5
  1. #1 GXP Brake Upgrade Questions
    Dec 2012
    Raleigh, North Carolina
    Hey guys so I just picked up front and rear GXP calipers and brackets for my 97 GTP. I know that I will need GXP rotors and pads. Will the stock brake lines work or will I need longer ones? Also I have mustang bullitt wheels that are 17x8 with a 45mm offset. They are on 245/50 tires. Will these brakes work with my set up?
  2. #2 Re: GXP Brake Upgrade Questions
    Oct 2014
    portland oregon
    I run front GXP's on my 97 aswell you will need longer lines i suggest Stainless lines from ZZP they firm up the system. I run 18's and have about a inch of clearance. IIRC 18 are required.
    There is a big brake thread on here that lays it all out. IIRC its a sticky in this section
    Ebay has slotted rotors and ceramic pads for good prices. its the rout i took anyways.. have fun stopping on a dime
  3. #3 Re: GXP Brake Upgrade Questions
    Dec 2012
    Quote Originally Posted by wowitsfast View Post
    Yeah I read over the big brake thread. It says GXP calipers require 17's not 18's.. And i will look into those stainless lines from ZZP. I found a pretty good deal on a set of four drilled/slotted rotors and ceramic pads on ebay! I just want to make sure the calipers will fit before I buy more parts...
  4. #4 Re: GXP Brake Upgrade Questions
    Oct 2014
    portland oregon
    If you question it take a wheel off unbolt current set up hang it off the strut. bolt one gxp caliper and put your wheel on see if it rubs
  5. #5 Re: GXP Brake Upgrade Questions
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    My Eagle Alloy 17x8 rims clear no problem. They have a 38mm offset.
    See this post for GXP brake hose part numbers. If you can find a GXP brake pedal, it is definitely worth the effort. It changes the fulcrum point which improves the brake pedal feel.
    2000 GTP Silvermist Coupe - GMR Torsen, Cartuning trans pan, GMPP Lowering & Handling Kits, TOGs, Corsa, Racetronix, GXP Brakes, Eagle Alloy 077s, HPTuners, etc.
  1. brake upgrade questions
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:22 AM
  2. Brake Upgrade
    By IAGXP in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 11:28 AM
  3. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  4. Brake upgrade
    By rocket69GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 12:35 PM
  5. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
