Thread: Inner tie rod
Results 1 to 6 of 6
  1. #1 Inner tie rod
    Jan 2017
    WI
    Just picked up a 2008 Grand Prix and am going through it bringing it up to snuff. Noticed a shimmy in the steering wheel so checked things out. Left wheel is very tight. right Wheel has quite a wiggle in it and it is not the outer tie rod. How do I know if it is the inner tie rod or the steering rack? If it is the inner does someone have a video\process for this? Thanks in advance.
    2008 Pontiac Grand Prix 115000 miles
    2003 Pontiac Bonneville-Silver
    2003 Pontiac Bonneville- Black
  2. #2 Re: Inner tie rod
    I do this on a lift but I just hang my body weight by the inner tie rod and have someone wiggle the tire at the same time.
    You could do it on the ground too if the vehicle was high enough. Though you'd be using your arms to pull down hard on the inner tie rod to remove the allowed movement in it. If it stops being loose with you pulling down on it and someone shaking the wheel at 9 and 3, it's normally the inner tie rod.
  3. #3 Re: Inner tie rod
    GTP Level Member buickman104's Avatar
    NYC
    lock the steering wheel. get under the car and wiggle.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Inner tie rod
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by buickman104 View Post
    Pretty sure these cars don't have the old school steering lock. Key on and brake to shift from park took it's place ??
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: Inner tie rod
    St. Louis
    Not sure about the 08, but my 00 GT has a steering lock, and I also have to have the key on and press the brake to get it out of park. Thought that was a standard thing...
  6. #6 Re: Inner tie rod
    NYC
    Oh, crap! I forgot this was an '08. I think only the 97-03 had steering lock.
