Thread: Dorman sway bar hitting catalytic converter.
Results 1 to 6 of 6
  1. #1 Dorman sway bar hitting catalytic converter.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    As the title says, just installed a dorman sway bar, 97-03 LCAs KYB struts and ZZP springs on a 06 GT. Using the provided endlinks. Any ideas?
    GPONA #1 Cyber Bully
  2. #2 Re: Dorman sway bar hitting catalytic converter.
    GTP Level Member buickman104's Avatar
    NYC
    Gotta take out your sway bar and flip it. Then it shouldn't hit your down pipe.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Dorman sway bar hitting catalytic converter.
    Kemmerer, Wyoming
    take the catalytic converter off and go with an offroad downpipe.
  4. #4 Re: Dorman sway bar hitting catalytic converter.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    The sway bar had directions for which side went where. Should I disregard them?
  5. #5 Re: Dorman sway bar hitting catalytic converter.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Anybody?
  6. #6 Re: Dorman sway bar hitting catalytic converter.
    you just might have it installed up side down. when it does hit the down pipe flipping it is the fix.
    none of your other suspension work has a thing to do with it either.
  1. 2005 GP LCA hitting sway bar end link?
    By mentalattica in forum Brakes/Suspension/Chassis
    Last Post: 08-09-2016, 12:13 PM
  2. Is this the Dorman Sway bar?
    By DrSnazzy in forum General Tech Discussion
    Last Post: 08-05-2013, 12:54 PM
  3. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  4. Dorman Fornt Sway Bar Squeaks
    By Joe942 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 07:06 AM
  5. Front Upgraded sway bar hitting.....
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2009, 10:20 AM
