Thread: Quickstrut replacement similar to stock FE3?
Results 1 to 6 of 6
  1. #1 Quickstrut replacement similar to stock FE3?
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    Looking to replace the struts on my 04 that I already changed to the 97-03 style sway bar on so I don't need the attachment point. Does anyone make a quickstrut replacement similar to stock FE3 or FE4?
  2. #2 Re: Quickstrut replacement similar to stock FE3?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The best you'll get out of a quick-strut is similar to FE2.
    If you feel like spending a little bit and going a little lower, ZZP does sell drop-in lowering spring/strut combos that come pre-assembled. And you can even go for the AGX's since you have the earlier sway bar design.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Quickstrut replacement similar to stock FE3?
    Nov 2012
    Madison
    Quote Originally Posted by Metal Links View Post
    Fck No.
    I saw an 04 cross traffic that must have just put new quickstruts in front but not in back. The front must have easily been 4 inchers higher than the back.
    Just swap the parts. Once you do it, you will see how easy it is.
    Then you can pick between FE3 or AGX and not throw your money at something that will be embarrassing to drive.
  4. #4 Re: Quickstrut replacement similar to stock FE3?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I used the OE GM front FE3 springs and struts. On the rear Monroe sells a FE3 OE spec quickstrut. I called and they said it is specific for the sport/ FE3 model. I used them and have the same ride height and they still feel fine after several years. But there are better performance options. I would stay away from KYB GR2 I had several blow out in little more than a year.
    MONROE 172471R
    {Click Info Button for Alternate/OEM Part Numbers} Quick-Strut (Rebate/Promotion Available!)
    Rear Right; w/ 17" Wheels
    $132.79
    Add to Cart
    MONROE 172471L
    Rear Left; w/ 17" Wheels
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #5 Re: Quickstrut replacement similar to stock FE3?
    Nov 2012
    Madison
    Well no sht man.
    How did you come across the oem style FE3s. Not like I would buy them.
    I can't have the stock ride height
  6. #6 Re: Quickstrut replacement similar to stock FE3?
    Dec 2013
    NJ
    Actually, I found Moog police/taxi quickstrut. I assume they are the FE4 used on Monte Carlo SS and police pursuit packages? They should fit and not have funky ride height, right? Part #ST8558
  1. S1X for S3 or similar and other valve train
    By SnowTh1ef in forum Wanted To Trade
    Last Post: 11-13-2014, 06:53 AM
  2. Ssc springs or something similar
    By shawnschuldt in forum Wanted To Buy - Parts
    Last Post: 08-29-2014, 10:38 AM
  3. Stock Replacement struts
    By silvermistgt2002 in forum General Grand Prix Discussion
    Last Post: 11-01-2013, 05:46 PM
  4. Stock Stereo replacement
    By Dukus in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2010, 07:20 PM
  5. How similar are the stock 99 t/b's vs. pre 98's
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2009, 04:37 PM
