Thread: Random ABS light, no codes, all speed sensors reporting.
Results 1 to 9 of 9
  1. #1 Random ABS light, no codes, all speed sensors reporting.
    GTP Level Member buickman104's Avatar
    NYC
    I have a random ABS light coming on my 2000 GTP. Hooked up the Red Brick MT2500 Snap-on scanner as soon as my Random ABS light comes on and i hook up the scanner, there are no ABS codes and all 4 wheel speed sensors are reporting. Any advice or suggestions would be greatly appreciated.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Random ABS light, no codes, all speed sensors reporting.
    It's going to be one of those thing where you will have to have the scanner with you when it blurts out what wheel it is. Likely one wheel all of a sudden just drops out and comes right back and that normally doesn't pop up a code. I'd have all 4 wheels on the scanner and have someone in the passenger seat watch while I drive it and see which wheel drops out.
    Seen this several times on chevy trucks and cars.
  3. #3 Re: Random ABS light, no codes, all speed sensors reporting.
    NYC
    When the problem is sudden like this, from your experience has the culprit usually been the wheel bearing or wiring?
  4. #4 Re: Random ABS light, no codes, all speed sensors reporting.
    NYC
    Thank you for the suggestion! I'll give it a shot and report back.
  5. #5 Re: Random ABS light, no codes, all speed sensors reporting.
    Normally the bearing itself.
    Not many have a bolt on wire harness, they run inside the back of the bearing. A lot of the chevy trucks you can unbolt the harness from the bearing and swap it if you had too.
  6. #6 Re: Random ABS light, no codes, all speed sensors reporting.
    St. Louis
    I'd be checking the wire harness that connects from the bearing to the main loom too. They are known to corrode (get dry wire) and cause random ABS lights. My 00 GT did this for a while and I just replaced the harness section. Went through the same thing. Checked all 4 hubs with my multimeter and they all showed signal.
  7. #7 Re: Random ABS light, no codes, all speed sensors reporting.
    Donating Users moddman's Avatar
    Midwest
    X2 ie. "check the front sensor harness". L+R (One each side.)
    Here is the harness:h**ps://w**.amazon.c**/Autex-970-040-Wheel-Speed-Sensor/dp/B01D30L9BM/ref=au_as_r?
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  8. #8 Re: Random ABS light, no codes, all speed sensors reporting.
    NYC
    Wow, that is cheap! Thanks! Hoping it is the wiring harness as my wheel bearings are only about two years old and there is no play.
  9. #9 Re: Random ABS light, no codes, all speed sensors reporting.
    Midwest
    h**ps://w**.amazon.c**/YourRadiator-YR237S-Replacement-Harness-Sensor/dp/B01IYB16ZO/ref=pd_lpo_263_lp_t_3/154-0031139-2671343?
    Even cheaper price.
    3.4" ZZP MPS Pull
  1. '08 GXP Random Air Bag light
    By HeavyChevy in forum General Grand Prix Discussion
    Last Post: 07-28-2015, 09:40 PM
  2. Knock sensors not reporting??
    By ntreftz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2013, 12:04 PM
  3. Random very high / fast idle speed...
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2013, 10:55 PM
  4. Random air bag light
    By stealthee in forum 04+ Specifics
    Last Post: 10-18-2011, 05:25 AM
  5. ABS,Traction Controll, and Speed Sensors issue.
    By 02Prix in forum General Tech Discussion
    Last Post: 12-08-2010, 02:12 AM
