Thread: banging from right rear suspension over bumps
Results 1 to 7 of 7
  1. #1 banging from right rear suspension over bumps
    Nov 2016
    N. California
    I guess I am assuming the banging is coming from the suspension. The car (2001 GTP) has Koni struts on it with about 80K miles, 160K miles on the car. The front suspension has had the tie rods replace, I don't know that the rear has had anything done but the struts.
    Any suggestions what to look for when I jack it up after work tonight?
  2. #2 Re: banging from right rear suspension over bumps
    sway bar end link or like mine the sway bar rusted through and the end link held it up but it was clanging off the exhaust.
  3. #3 Re: banging from right rear suspension over bumps
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    My r/r noise was the E-brake cable flopping around, I could feel it in the drivers side front floor too...
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: banging from right rear suspension over bumps
    GT Level Member mguzzo's Avatar
    Buffalo NY
    exhaust pipe banging on frame
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: banging from right rear suspension over bumps
    hangover park IL
    The chassis side sway bar bushing on my 2004 is missing and that is my banging sound. The end links are fine
    ~James~ Psychotic Gearhead
  6. #6 Re: banging from right rear suspension over bumps
    Nov 2016
    N. California
    Quote Originally Posted by mguzzo View Post
    I didn't know these cars had a frame
    Looks like this has turned into a weekend task, will get to it tomorrow.
  7. #7 Re: banging from right rear suspension over bumps
    GXP Level Member
    Mar 2015
    Tomball
    My 05 started making a rattling a while ago that I attributed to the cable for the E-brake hitting the trailing arm. Then today the rattling started getting worse and at about 20 mph the back end felt a little wobbly and the toe link has come loose and apparently wrecked the threads.
    Jeff
  1. Shudder/Chatter from rear driving over bumps
    By Yarbeau in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2014, 03:43 PM
  2. Suspension Clunking Noises going over expansion joints and moderate bumps
    By Crispykit in forum General Grand Prix Discussion
    Last Post: 09-24-2013, 04:06 PM
  3. Squeak in rear end over bumps
    By 2007GrandPrixGT in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2012, 01:29 AM
  4. rear suspension????
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-07-2010, 04:29 PM
  5. rear suspension, 04+
    By sportred04 in forum General Tech Discussion
    Last Post: 03-09-2010, 07:20 PM
