Thread: Addco or gmpp rear sway bar?
Results 1 to 14 of 14
  1. #1 Addco or gmpp rear sway bar?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys trying to beef up suspension a little. Obviously the addco bar is better but my question is it really worth the extra 140$ish over the gmpp bar. I'm not autocrossing the car or anything but would like a good bump over stock as far as handling goes. Thanks guys.
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Addco or gmpp rear sway bar?
    GTP Level Member buickman104's Avatar
    NYC
    I depends on what you want. The car does noticeable handle better with the Addco over the GMPP. I've had all three Stock<GMPP; GMPP<Addco. But in the end don't expect the car to handle any better than a Nose heavy FWD car. Also if you go for the addco make sure to use lock-tite on the end link studs. As the Addco is thicker there is less stud (moog endlinks) to crank on, so the nuts backed out and bent the studs.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Well is the gmpp stuff a noticeable improvement over stock?
  4. #4 Re: Addco or gmpp rear sway bar?
    NYC
    Yup. It is noticeable, but then the Addco would feel like a huge jump over stock. :P
  5. #5 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Dang your making this hard! The only thing is if I went with the gmpp kit I could also afford to get front and rear stb's
  6. #6 Re: Addco or gmpp rear sway bar?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    GM Part number: 12498648, 12498642, 12498643. Add some Don Rome brackets and you will be good to go. That set is the best performance per $ in my opinion.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  7. #7 Re: Addco or gmpp rear sway bar?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Don Rome brackets are overpriced, I made my own for 15 bucks.
    I like making my own stuff, though...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #8 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Do the bars come with mounting hardware?
  9. #9 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Ok nevermind
  10. #10 Re: Addco or gmpp rear sway bar?
    Oct 2015
    If I had to pick one to do first I'm assuming the sway bars are going to make more of a difference then the stb's right?
  11. #11 Re: Addco or gmpp rear sway bar?
    Oct 2014
    Frederick, MD
    Stb's make a big difference, IMO... but the sways will probably be a bigger improvement, especially with poly bushings.
  12. #12 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Does anyone have the part #s for the poly bushing for the gmpp bars?
  13. #13 Re: Addco or gmpp rear sway bar?
    Nov 2011
    NY
    Go with the Dorman solid bar up front and thee Adco bar for the rear. GMPP strut tower braces are ok with the Don Rom brackets. The brackets come with the hardware and DR is a great seller. Stands by his product, I have his diagonal braces as well and he refinished them pretty much for cost of shipping as I've had them a Long time and they needed it. In addition, you'll want new control arms (bushings, but easier to just replace whole unit), and BMR rear lateral arms. You do all this and you'll begin to like the handling a bit : ) new struts help too, the KYB Quick Struts are fine, top it all off with Energy Suspension Poly bushings in everything.
    Now you may be thinking gee I don't need all that, but yeah, you do. Suspension is a funny thing, it's gradual when it diminishes, replace just a piece here or there, you won't notice a huge difference. So if you want to feel and enjoy what fixing up your suspension will do for you, save up and do it all at once and you'll realize the fruit of your efforts.
    Good Luck!
  14. #14 Re: Addco or gmpp rear sway bar?
    Oct 2015
    Ya I know the bushings in my lca are going although I haven't developed any clunk or vibrations yet.
  1. The Addco rear sway bar is not dead!
    By Frosty in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2020, 06:14 PM
  2. Addco 639 Rear Sway Bar
    By GTPNovak in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2017, 06:01 PM
  3. Rear GMPP Sway bar from 00 GT on a 08 SE ?
    By Le Patriote in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2013, 03:54 PM
  4. gmpp rear sway bar help
    By stanbob123 in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2010, 09:29 PM
