Thread: Rear swaybar rubs against inner ps strut.
Results 1 to 9 of 9
  1. #1 Rear swaybar rubs against inner ps strut.
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    I recently installed wbs rear lateral arms in my 01 gtp. I then went to go and get the rear realigned. As i was comming home I heard a slight faint creaking/clunking sound comming from the back of the car. When i got home i pulled the car in the garage and put the rear up on ramps and started looking around. I then noticed that on the passenger side my swaybar(gmpp bar) is rubbing against the inside of the strut(kyb). Anybody else ever have the problem?
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  2. #2 Re: Rear swaybar rubs against inner ps strut.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Find a different shop to get it aligned.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Rear swaybar rubs against inner ps strut.
    Sure it was installed correctly?
    I've installed multiple sways...front and rear...
    Never had a rubbing issue.
  4. #4 Re: Rear swaybar rubs against inner ps strut.
    Yup, everythings tightened down and bolted up right. Ive done a few swaybars myself and im kind of puzzled. Doubled checked the lateral arms.
  5. #5 Re: Rear swaybar rubs against inner ps strut.
    Nov 2015
    WI
    Sounds like you need to install sway bar lateral locks. I bet the driver side is really far away from the strut and the entire sway bar shifted to one side.
  6. #6 Re: Rear swaybar rubs against inner ps strut.
    Eh, the driverside looks pretty normal to me, not to mention that the swaybar has stoppers(or nubs) where the bushings go to prevent the swaybar from shifting.
  7. #7 Re: Rear swaybar rubs against inner ps strut.
    Update. Got the rear alignment done again and it helped slightly. I think I might go the route of using the lateral locks gtpnovak was talking about. My question with those is will it have any negetive effect on handling? For instance, if i were to put a lock on just the side thats rubbing?
  8. #8 Re: Rear swaybar rubs against inner ps strut.
    Nov 2015
    WI
    You say there is little nubs or stoppers already, i am not sure the lateral locks will help if those nubs are functioning correctly.
  9. #9 Re: Rear swaybar rubs against inner ps strut.
    FIXED. So i got my hands on a pair of swaybar lateral locks, put the rear of the car on ramps this morning and loosened up the swaybar bushing clamps. Using a small prybar between the swaybar and the strut I gently shifted the swaybar and had just enough room to put one of the locks between the existing nub and the bushing. Not only did it stop the rubbing, but now my swaybar is evened out on Both sides. Problem solved.
  1. 22mm rear swaybar bushing
    By jshow816 in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2016, 07:25 AM
  2. Rear swaybar for 2005 gtp compG
    By Sudden in forum Brakes/Suspension/Chassis
    Last Post: 11-28-2014, 03:52 PM
  3. Rear strut/springs
    By danwilson1959 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2014, 07:43 AM
  4. BMR strut tower brace rubs alternator
    By schlabby in forum Brakes/Suspension/Chassis
    Last Post: 02-02-2012, 07:24 AM
  5. Largest available rear swaybar?
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 10:02 PM
