Hi All,
I have a bad front wheel bearing hub which is making noise and has excessive excessive play. I am buying a Moog bearing but wanted to know a few things that I read on other sites. A few sites recommended replacing the axle nut and hub securing bolts due to fatigue. The statement was more like they dont re-torque very well. Do they need to be replaced or is this more for peace of mind? Also the same question for the axle nut.
When cleaning up the area where the new bearing will go what type of grease is recommended to coat the mating surfaces and the drive shaft spines? I was going to use Mobil one synthetic, would something else be more appropriate?
Also recommended torque specifications. I have read a few posts here and they seem pretty straight forward but I have heard 2 different specs for the drive shaft nut. Is it 118 ft lbs or 150 ft lbs? The securing nuts should be 115 - 118 ft lbs.
Thanks for the forth coming information.
