Thread: Power Steering Fluid in Master Cylinder
Results 1 to 13 of 13
  1. #1 Power Steering Fluid in Master Cylinder
    SE Level Member TuKoolGTP's Avatar
    Nanamo, BC, Canada
    I can't believe I did a bonehead move and topped up the master cylinder with power steering fluid. Didn't realize it for 2 weeks. Once i realized what I did, I flushed the system with new Brake Fluid. But I assume it was too little too late.
    So I think I am in for a brake system rebuild and flush in the near future.
    4 Calipers
    4 Brake Hoses
    Master Cylinder
    ABS Module
    Any other components in the system with rubber seals? (98 GTP)
    Custom CAI | PowrTuner | AL 104s | TBS | 3" DP | Res Del | 180 TS | 3.6 | PEM
  2. #2 Re: Power Steering Fluid in Master Cylinder
    you dont need to replace any of that stuff. suck the res dry, re fill it, then flush and keep it full as you flush it.
  3. #3 Re: Power Steering Fluid in Master Cylinder
    Nanamo, BC, Canada
    That's exactly what I did, flushed all 4 corners.......
    Research says if the power steering fluid was in there for any length of time, all rubber seals are contaminated and will eventually swell and fail. Just a matter of when.
  4. #4 Re: Power Steering Fluid in Master Cylinder
    it likely never left the master's res. id not worry bout it. brakes feel ok, carry on. save your money, unless you want to upgrade to f bodys and SS lines. putting new stock crap back on is just a waste of money.
  5. #5 Re: Power Steering Fluid in Master Cylinder
    Nanamo, BC, Canada
    Brakes feel OK. Hopefully it stays that way.
  6. #6 Re: Power Steering Fluid in Master Cylinder
    Jul 2010
    Coquitlam,BC,Canada
    ^ This.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Power Steering Fluid in Master Cylinder
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I personally would flush the system with denatured alcohol to remove any trace of contamination and replace the master cylinder. You don't know what the oil did to the seals on the pistons. They may be fine. Or they may be distorted, swollen, soft, and ready to fail. A reman master cylinder is probably $50-100 bucks on RockAuto. Is your life worth it over a hundred bucks and couple hours of labor?
    You just don't know. Everything could be fine or every seal and hose could be on its way out the door. I personally tend to be more conservative when it comes to the brake system considering the costs of failure! (I investigate accidents for a living and have seen enough brake system failures over the years to be a bit cautious and conservative in that regard.)
    If there is any signs of brake failure, soft pedal, sticking caliper, hot brake, etc I would replace all the parts you mentioned.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  8. #8 Re: Power Steering Fluid in Master Cylinder
    Nanamo, BC, Canada
    I agree. There may not be any problems. But I don't like driving around wondering if/when/how they are going to give trouble or fail.
    Leaning towards replacing parts over the Christmas holidays.
    Which brings me back to my original question. Are there any other brake components with rubber seals?
  9. #9 Re: Power Steering Fluid in Master Cylinder
    Jul 2014
    Toledo, OH
    4 caliper rebuild kits and probably $5-10 each
    4 brakes hoses at $10-20 each
    1 master cylinder $50-100
    Check master cylinder cap
    ABS hydraulic module (yikes) that one may be a bit pricey
    Brake fluid, alcohol, and shop supplies $20
    I think that's it.
    You could always just pull the front left caliper and hose. Pull apart the caliper and see how the boot and seal look. Then inspect the inside of the hose. Any varnish, deposits, softening, flaking, brittleness, etc. Gives you an idea if you need to replace the system or just clean and reassemble and be ok.
  10. #10 Re: Power Steering Fluid in Master Cylinder
    your over thinking this 100%, f it, dont spend any money on fixing stuff thats not broken.
  11. #11 Re: Power Steering Fluid in Master Cylinder
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Just a thought, why not pour some clean brake fluid in a clear jar, then add clean p/s fluid on top and see if they mix?? or hopefully p/s stays on top, then you'll know if it mixed or not?? My 0.02 ......E
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  12. #12 Re: Power Steering Fluid in Master Cylinder
    May 2016
    Rouge Island
    Quote Originally Posted by cheatah faheatah View Post
    OK, I was curious and p/s fluid floats on top of brake fluid!! It bobs right to the top, I even swirled it around really good and the p/s breaks down into little globs, but it settles back into a uniform mass on top...The More You Know! *
  13. #13 Re: Power Steering Fluid in Master Cylinder
    Jul 2010
    Coquitlam,BC,Canada
    I tried to find a video on this topic, but no luck. I did learn that you shouldn't put Pool Shock in your brake system. LOL
    https://www.youtube.com/watch?v=w87XSRswUT8
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Power steering fluid
    By themantis in forum General Grand Prix Discussion
    Last Post: 04-22-2016, 09:34 AM
  2. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  3. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  4. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  5. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
