Thread: GXP rear brake caliper rebuild
Results 1 to 5 of 5
  1. #1 GXP rear brake caliper rebuild
    SE Level Member Acdc88's Avatar
    Jul 2015
    St Peters
    Has anyone rebuilt a rear set of GXP calipers? I can't find the correct rebuild set. I've picked up a dorman set and a set from Advance Auto and neither set fits correctly.
    02 GT : BMR Trailing Arms, F&R Lateral Arms, F&R Strut Tower Braces. Progress F Anti-Sway Bar. Addco R Anti-Sway Bar. Moog Problem Solver Bushings & "CK" Control Arms. K&N CAI. HV3. MSD Coils and Wires. ZZP 1.0. ZZP Front P-Log. ZZP 2.5" Cat'd Downpipe. C5 front brakes, GXP rears. Full Borla Cat Back. BC Coils. Niche 18s
  2. #2 Re: GXP rear brake caliper rebuild
    Dec 2013
    Enfield
    I have not,but this should be correct. Says for JL9 option code.
    http://www.rockauto.com/en/moreinfo....440277&jsn=398
  3. #3 Re: GXP rear brake caliper rebuild
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    I did and I found the kits on eBay.
    CENTRIC Part #63032 (rear caliper, order TWO kits to do BOTH calipers)
    CENTRIC Part #66014 (front caliper, order TWO kits to do BOTH calipers)
  4. #4 Re: GXP rear brake caliper rebuild
    Jul 2015
    St Peters
    Thanks guys. I ordered a set of the centric 63032 yesterday. If those don't work I'll give the acdelco kit a shot.
  5. #5 Re: GXP rear brake caliper rebuild
    GTP Level Member
    Pittsburgh
    when I did mine I went the same Advance Auto Route and they did not work.
    I ordered the CENTRIC 14363032 from Rock Auto for the rear and had no problems
    2003 SSEi,
  1. double piston rear passenger brake caliper?
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 11-27-2015, 08:33 PM
  2. Helicoil the rear brake caliper hose hole?
    By industrialfish in forum Brakes/Suspension/Chassis
    Last Post: 07-13-2014, 02:07 PM
  3. Rear caliper rebuild or replace?
    By stocker in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2014, 09:24 AM
  4. Putting the parking brake cable on the rear caliper
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 03:32 PM
  5. caliper rebuild
    By Logan541 in forum General Tech Discussion
    Last Post: 02-10-2013, 11:16 AM
