Hi, and thanks for taking the time to read this I have "4" problems that seemingly all started at once, and has progressively gotten worse over the last 1,000 miles. Here are the symptoms. 1) Light duty clunking over minor imperfections in the road that sounds like stab-links are worn, 2) Creaking/Popping noise that you can feel & hear while turning the wheels (you can feel this through the strut mounts), 3) Single audible clunk on initial forward take off after a stop (car has new motor mounts already), and 4) if you turn the wheels with the vehicle on the ground and engine off, you will get a single clunk from somewhere under the front of the car, and with that clunk, the steering wheel position will change!
Symptoms 1, 2, and 3 seem to almost be non-existent, or minor during the first few minutes of driving (weird!).
Oh, and the car seems to wander more than it should. Tie rods and ball joints both sides all feel very tight. Car has 97K miles.
Now here is what I have done so far. Since most the noise seemed to favor the drivers side, I replaced the left upper strut mount, the left stab link, and the left lower control arm. No change. Also replaced steering intermediate shaft. Motor mounts though done in December, could be faulty, but doubtful. I dont abuse the car, and is completely stock.
So before I drop $500 on a pair of new struts for this car to "see if the noises go away", or replace the rack due to symptom number 4, has anyone experienced this?
Thanks in advance for sharing your experience or suggestions.
