Thread: Steering problem
Results 1 to 11 of 11
  1. #1 Steering problem
    Apr 2014
    Central NJ
    Feel free to move this to the correct thread if I put this in the wrong place.
    I have a 2004 GTP Comp G and noticed that while idling, it is very hard to turn the wheel to the left and easy to turn to the right. Giving some power clears the issue. After some research, it seems I would need a new steering rack. I am not very knowledgeable about cars in general and I only know the basics. My question is: What do you think it is and could this be caused by something else? My EBCM/abs module hasn't been working since last year and I hope it's not because of that.
    Any help would be appreciated. Thank You!
  2. #2 Re: Steering problem
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Check your belt and make sure its tight. You might get lucky and its that. Put your thumb on the belt and if u can push it down well over an inch, then u need to tighten that sucker up��
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  3. #3 Re: Steering problem
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Make sure the power steering fluid is full. If low add Lucas power steering fix in there and make sure there are no major leaks. Check the belt like said above, but make sure the tensioner and idler pulleys are in good working order. If above fails I would suspect a power steering rack.
    The ABS/EBCM should not affect it, that just means you have no traction, stability control, or magnasteer. check the ground wire on the ebcm, there is a splice procedure to solder and re-ground it. Sometimes that will fix the EBCM issue.
  4. #4 Re: Steering problem
    Quote Originally Posted by willie14 View Post
    how you gonna tighten up a serpentine belt? it runs off a tensioner. new belt or tensioner is the only way.
    hard to the left easy to the right is a rack on the way out. soon it will be hard all the time to the left with or with out giving it gas, then hard all the time right or left.
  5. #5 Re: Steering problem
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I agree with Rick. I'd add that on the older ones at least, the fluid leaks into the boot. The rack failing caused the exact same symptom (pull right, hard turning left), but I was at highway speed. Not fun. A way to check is if the reservoir seems to keep needing some added, and you're not seeing a spot in the driveway...well, it's going somewhere.
    Mine's a little sticky, too. I plan to flush out the fluid. Here's a link ~ http://www.grandprixforums.net/threa...00-3-8L-Engine
  6. #6 Re: Steering problem
    low fluid would be hard to steer both ways.
    rack does not have to leak to go bad, mine took a crap with no leaks, hard to the left, till there was no power at all.
    and yes i changed the pump first, same problem.
  7. #7 Re: Steering problem
    Jun 2016
    westland mi
    Hey he could get lucky and that tensioner pulley went bad. If so cheap fix..
  8. #8 Re: Steering problem
    GTP Level Member
    Jun 2016
    Cleveland ohio
    he would probably experience more symptoms if it were the belt I would think. like intermittent charging system failure and possible overheating. definitely worth a shot. Like scottydoggs said it is more than likely the rack but rule out everything else first.
  9. #9 Re: Steering problem
    oh its a bad rack alright lol
  10. #10 Re: Steering problem
    Jun 2016
    westland mi
    Lol
  11. #11 Re: Steering problem
    St. Louis
    Just change the rack out before you get stuck in a situation where it fails completely like mine tried to do.. in the middle of a busy intersection on a left turn yield. I've driven manual steering cars that required less effort than trying to complete that turn w/o getting broadsided. Just take Scotty's word for it, lol. Mine failed in the exact same way as you are describing and I had limped it along for a long time by adding Lucas to it until it finally had enough.
    While replacing the rack I also flushed the power steering system out. Made a huge difference. Pump hasn't whined since I got the air out of the system and that's with the original pump sitting at 374K miles.
  1. Problem with Steering
    By 92builtbird in forum 5.3L V8 (LS4)
    Last Post: 06-03-2014, 09:02 PM
  2. Steering Problem
    By GrandPrixMI in forum General Tech Discussion
    Last Post: 04-18-2014, 07:57 PM
  3. steering problem
    By GTP Ryan in forum General Tech Discussion
    Last Post: 12-06-2009, 04:40 PM
  4. steering problem
    By stanggreg90 in forum General Tech Discussion
    Last Post: 10-16-2009, 10:05 AM
  5. Steering Problem Please Help
    By 2000grandprixGT in forum General Tech Discussion
    Last Post: 03-08-2008, 02:00 PM
