Thread: Wheel bearings
Results 1 to 20 of 28
  1. #1 Wheel bearings
    Oct 2013
    michigan
    Ok what does everyone use for front wheel bearings? I have been through two sets in the last two years. First set was Raybestos and then the second was Moog. The Moogs have recently started growling. I am going to get them warrantied. However any one else's car eat the front bearings? The moogs have lasted longer than the Raybestos. Figure 20k miles per set, not impressed.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  2. #2 Re: Wheel bearings
  3. #3 Re: Wheel bearings
    Oct 2013
    michigan
    timken.
    are you torquing them correctly?
    Yes, I have been talking to a couple others and going to try a different approach on them.
  4. #4 Re: Wheel bearings
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I went with SKF, and they've been through hell and back. lol only 6k on them but 2 trips over the ocean and a busted CV joint, still going strong.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: Wheel bearings
    SWPA
    I've had Moogs in the front of my car, and one rear for 2.5 years with no issues on the front ones. The rear bearing did fail, but was replaced under warranty last year sometime and has been problem free since.
  6. #6 Re: Wheel bearings
    Jul 2010
    Coquitlam,BC,Canada
    On my first front wheel bearing replacement, I used SKF. Both bearings were replaced. Three years later, left front growling, replace with SKF. One year later, right front growling, replace with Delco. One year later, right front setting ABS light. Replace with Delco; this one was my fault for pinching the wire.
    I don't get why these cars eat bearings. I had my Bronco for 15 years and not once did I change a wheel bearing. Must be a GM thing. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Wheel bearings
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Moog bearings for me... I've bought 4 fronts across a couple different cars, and they've held up without issue. Plus available at advance auto with discount codes.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  8. #8 Re: Wheel bearings
    GTP Level Member
    Oct 2014
    I have used Delco on most so far no issues. Keeping fingers crossed.
  9. #9 Re: Wheel bearings
    Quincy, Mass
    I go with timken and only have to do it once. Using the parts store ones made in China I went through them once a month.
    No more GP 04 Impala SS Indy:
  10. #10 Re: Wheel bearings
    SWPA
    For what it's worth Timken is made in China now too.
  11. #11 Re: Wheel bearings
    Jul 2010
    Coquitlam,BC,Canada
    My SFK's were made in Korea, and Delco's made in China.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Wheel bearings
    Quincy, Mass
    Seriously?
  13. #13 Re: Wheel bearings
    seems like too loose or too tight and you just mess them up after you drive on them. they gotta be just right.
  14. #14 Re: Wheel bearings
    Oct 2013
    michigan
    Too tight was the consensus. Gonna back it down a little
  15. #15 Re: Wheel bearings
    SWPA
    Check out country of origin around half way down the page
    https://www.amazon.com/Timken-513179...productDetails
  16. #16 Re: Wheel bearings
    gardner,mass
    It actually depends on the vehicle.8
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  17. #17 Re: Wheel bearings
    SWPA
    Quote Originally Posted by Timing View Post
    Every Timken ad on Amazon I have clicked on so far all say China.
  18. #18 Re: Wheel bearings
    GTP Level Member
    Oct 2014
    I feel like there is good China and bad China.
  19. #19 Re: Wheel bearings
    SWPA
    Quote Originally Posted by markpa View Post
    Oh, I agree with you. I just wanted to point out to Swigs that Timken was also made in China after his post.
  20. #20 Re: Wheel bearings
    New York
    Timkin on the GP...fronts have 100,000 miles since the replacement and the timkin rears have about 80,000 miles and still going strong. You must torque them correctly! Do not use any cheaply priced wheel bearing hubs..they will fail and often quickly. Timkin, Moog, SKf bearings are generally 2-3X the price of the cheap ones.
    On my Chrysler 300, I recently replaced the fronts with SKF bearings....good so far! SKF says 100,000+ miles life expectancy but they were $100 each!
    You must use a torque wrench with the correct setting for your car.
  1. ABS/Non-ABS wheel bearings
    By ThunderTC88 in forum General Grand Prix Discussion
    Last Post: 10-10-2014, 03:39 PM
  2. Wheel Hub Bearings??
    By misterman in forum General Tech Discussion
    Last Post: 05-28-2011, 09:06 AM
  3. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  4. Wheel Bearings
    By JAllegar in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2009, 02:57 PM
  5. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
