Thread: ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
Results 1 to 5 of 5
  1. #1 ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    All of these lights have come on randomly at the same time. Once they come on, they stay on until I turn the engine off and let the car sit for a few hours. But will come back on after 20-30 minutes of driving again.
    2007 Grand Prix GXP
    Here are the lights:
    ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on. Attached Images
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  2. #2 Re: ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
    bad wheel hub is the first guess.
    best to get it scanned follow the code/codes.
  3. #3 Re: ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
    Jul 2010
    Michigan
    Common for all of that to come on at once? All of those functions go through the sensor on the hub?
  4. #4 Re: ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
    bad hub can turn all them lights on. odd as it seems.
    bad hubs reset when the cars re started, once your driving, hit a bump or take a turn the light can came back on.
    your steering gets firm too when the abs light and all comes on. thats your magna steer being shut off due to the abs light.
  5. #5 Re: ABS,T/C,Brake, Stablity Control, and Variable Steering lights all on.
    Yoga city
    a hub will not throw a variable steering message. That still works when the hub is bad and will have a abs light and tc light. If you get a brake light also I would be looking at the ebcm it self. get it scanned.
  1. ABS Service, Traction Control Service & variable effort steering.
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 06-10-2017, 08:43 PM
  2. ABS, Traction Control and Variable Effort Steering disabled.
    By cameron92 in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2014, 07:14 PM
  3. variable steering/ABS/Traction/brake
    By DMPsixes in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2013, 07:44 PM
  4. is there a way to tell if my car has variable steering?
    By Doug 97 gtp in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2012, 10:41 PM
  5. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
