Thread: FE4 or non-FE$
Results 1 to 6 of 6
  1. #1 FE4 or non-FE$
    SE Level Member sn95gt50's Avatar
    Jul 2008
    I have an 08 GP 3.8L, ABS & Traction Control.
    Emergency brake cable seized up holding the brake on, plan to replace both.
    Looking at Rock Auto for Emergency Brake cables (rear ones) and the specify FE4 or non-FE4. How do I know which one I have?
    Is this a pretty easy job? looks fairly straight forward.
    Thanks,
    John
  2. #2 Re: FE4 or non-FE$
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Find your RPO sticker.
    GPONA #1 Cyber Bully
  3. #3 Re: FE4 or non-FE$
    Jul 2008
    Is that located on the door jam?
  4. #4 Re: FE4 or non-FE$
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    In the trunk. Either on the deck lid or in the spare wheel well.
  5. #5 Re: FE4 or non-FE$
    Jul 2008
    Thanks, will look at lunch.
  6. #6 Re: FE4 or non-FE$
    Oct 2011
    Toledo, OH
    FE4 should only be for the GXP.
    7"
