Thread: Ssc lowering springs, not really lowered
Results 1 to 11 of 11
  1. #1 Ssc lowering springs, not really lowered
    Apr 2012
    weymouth, Ma.
    I just installed the ssc lowering springs on agx struts. The car didn't lower that much. What springs drop the car lower than these ? Also what about removing the isolators would this drop it more and would it ride ok ? Thanks !
  2. #2 Re: Ssc lowering springs, not really lowered
    They need to settle and take quite awhile to do it and leave the isolators alone
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  3. #3 Re: Ssc lowering springs, not really lowered
    Give them a few thousand miles to work in.
  4. #4 Re: Ssc lowering springs, not really lowered
    Nov 2012
    Madison
    SSCs on 2 month old FE3s in the sig.
    Did you take before and after measurements? Should be around the 1 3/4 to 2 mark for a drop.
    What year and style of springs you get......97, 04, or GXP set
  5. #5 Re: Ssc lowering springs, not really lowered
    Apr 2012
    weymouth, Ma.
    This is what it look like, wheels are 19'. I have only put about 100 miles on the new springs.
    Ssc lowering springs, not really lowered Attached Images
  6. #6 Re: Ssc lowering springs, not really lowered
  7. #7 Re: Ssc lowering springs, not really lowered
    Jul 2010
    Coquitlam,BC,Canada
    SSC's and Monroe struts......
    The rear dropped 5/8", and the front 1 3/16".
    And four years later....
    No current measurements, but hasn't changed much.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Ssc lowering springs, not really lowered
    Minnesota
    I almost want to say you're going to start rubbing but I could be wrong, that looks awfully close without fully settling. I have 18's on SSC's and GR2's
  9. #9 Re: Ssc lowering springs, not really lowered
    Apr 2012
    weymouth, Ma.
    what springs will lower my car more than the ssc?
  10. #10 Re: Ssc lowering springs, not really lowered
    Apr 2012
    Goderich, Ontario
    Coilovers
    -Paul Walker
  11. #11 Re: Ssc lowering springs, not really lowered
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Eibachs. 18" wheels. No scraping issues at all. Others have said the ride is harsh with Eibach Pro-kit springs. Model # for w-body cars is 3865.140
  1. What needs done to remove Lowering Springs and go back to stock springs?
    By NotEnoughGPs in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2015, 09:49 PM
  2. Looking for Lowering Springs
    By 505pike in forum Wanted To Buy - Parts
    Last Post: 02-26-2013, 05:34 PM
  3. lowering springs
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 11-27-2008, 10:22 PM
