Thread: 2007 GXP calipers OEM discontinued - need aftermarket
Results 1 to 6 of 6
  1. #1 2007 GXP calipers OEM discontinued - need aftermarket
    Aug 2015
    florida
    GM has discontinued the RED rear calipers/brackets for my 2007 Grand Prix GXP. I can find the aftermarket left rear all day, but not the right rear. Any suggestions? Such as, the xzy car fits this one too, or a super secret company I can't find via Google??? Thanks
  2. #2 Re: 2007 GXP calipers OEM discontinued - need aftermarket
    St. Louis
    Local GM dealer
    junkyard
    carpart.com
    gmpartsgiant.com
    gmpartsdirect.com
    this link on Amazon-> http://www.amazon.com/s/ref=sr_pg_1?...qid=1461381939
  3. #3 Re: 2007 GXP calipers OEM discontinued - need aftermarket
    Aug 2015
    florida
    Thanks for going to the work of looking on Amazon, unfortunately, the ones in that link (and when I searched too) all do not fit the GXP if you read the description. I also tried all the other links you provided before. I did find some on eBay, but the seller has been unresponsive about expedited shipping... So, we decided to try the caliper paint you can buy and a pair of the grey/black ones that I can find pretty much everywhere. Fingers crossed the painting looks good.
  4. #4 Re: 2007 GXP calipers OEM discontinued - need aftermarket
    Apr 2016
    Edmonton Alberta Canada
    Does anyone know if they are like the Comp G calipers? Just regular calipers that GM painted?? Manufacturers are required to carry replacement parts for their vehicles for x number of years after production stops. Doesn't really make sense that x would be 10 years. You could probably find calipers at a GM dealer for a lot older cars that they keep in stock. Just sayin.
    Glen
  5. #5 Re: 2007 GXP calipers OEM discontinued - need aftermarket
    hangover park IL
    Moradparts.com
    it is possible that the bean counters only allowed for a larger caliper bracket to move the OE GP/Fbody caliper for the larger GXP rotor, but it doesnt seem likely that its the compG, the compG doesnt use the same style parking brake or knuckle/parking cables.
    to put GXP rears on the CompG i have required swapping out everything.
    youd be better off to get loaded calipers/rotors for a std/base/GTP 04-09 W body and swapping to them.
    you dont see many left because it was limited production, and it seems way too many people tighten the banjo bolts and strip the threads out of the caliper
    the GXP calipers/etc are powder coated, the CompG cars were painted calipers (std brakes)
    ~James~ Psychotic Gearhead
  6. #6 Re: 2007 GXP calipers OEM discontinued - need aftermarket
    Apr 2016
    Quote Originally Posted by Turbocharged400sbc View Post
    Moradparts.com
    The cheap buggers. Figures. The rotors were slotted and drilled on the GXP's too weren't they?
    Glen
  1. Looking for a discontinued part for my GXP
    By ivette7 in forum Introductions/Noob Questions
    Last Post: 08-16-2015, 03:00 PM
  2. 2004 through 2007 Cadillac CTS Dual piston calipers.
    By SuperchargedIntrigue in forum Brakes/Suspension/Chassis
    Last Post: 01-07-2015, 12:43 PM
  3. Hitler hears about Pontiac being discontinued
    By Kasey in forum General Grand Prix Discussion
    Last Post: 05-10-2012, 09:43 AM
  4. 1.95's discontinued
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 09:42 AM
