Thread: New Parts
Results 1 to 7 of 7
  1. #1 New Parts
    May 2012
    Canada , Sarnia
    Need new tires and wheel alignment what would be best to replace before the alignment ?? car has 312k
    - Control Arms
    - Tie Rods
    - Sway Bar
    - Stabilizer Bar
  2. #2 Re: New Parts
    St. Louis
    Depends on when the last time the arms and tie rods were replaced. If it's been a while then I'd do those 2. If the bars are junk then do those too.
  3. #3 Re: New Parts
    Well doing the control arms and tie rods will throw the alignment out, so you'd only have to replace those first to need the alignment done.
    The sway links and bar itself can be done anytime, it does not mess with the alignment of the vehicle.
  4. #4 Re: New Parts
    May 2012
    Canada , Sarnia
    Went and got
    - All Moog Brand
    - Control Arms
    - Outter Tie Rods
    - Inner Tie Rods
    - Sway Bar Link Kit
    I'm I Missing Anything ???
  5. #5 Re: New Parts
    St. Louis
    Just the alignment after you replace all of those as FFDP stated. You may need a special tool to replace the inner tie rods which you can likely rent from a parts store.
  6. #6 Re: New Parts
    May 2012
    Canada , Sarnia
    I wont be installing those lol I will be going to the local shop I have been going to for years
  7. #7 Re: New Parts
    Apr 2016
    Edmonton Alberta Canada
    Quote Originally Posted by gordster1122 View Post
    You're probably just worried the OPP will spank you if they found out you did it yourself.
    Glen
  1. Replies: 29
    Last Post: 09-03-2014, 09:42 PM
