Thread: zzp stage 2 axels
Results 1 to 18 of 18
  1. #1 zzp stage 2 axels
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Has anybody tried ZZPs stage 2 axels? They're supposed to be the best axels you can get for a 3800.
    Any thoughts, pros or cons?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: zzp stage 2 axels
    hangover park IL
    Ive been snagging minty low mile shafts anytime I find em in the yard....20$ each
    At this point I want the axles as the fuses. ...
    ~James~ Psychotic Gearhead
  3. #3 Re: zzp stage 2 axels
    I liked stock axles, they are plenty strong.
  4. #4 Re: zzp stage 2 axels
    Buffalo
    Quote Originally Posted by Turbocharged400sbc View Post
    This Good call
  5. #5 Re: zzp stage 2 axels
    I break stuff selliott's Avatar
    Kansas City
    I'm just running a set from O'Reilly with a lifetime warranty
  6. #6 Re: zzp stage 2 axels
    Nov 2011
    NY
    Quote Originally Posted by Dee23 View Post
    says who? ZZP? Lol...
    Yeah, call ZZP and ask for them to explain the "Stage II"... Post it here, I could use some entertainment ; )
  7. #7 Re: zzp stage 2 axels
    hangover park IL
    primary issue ive come across is that high mph cars need the axles disassembled and the grease quantity reduced by half.
    its sorta rough on a boot with the dynamic weight of 100lbs of grease trying to find an exit, especially if it all settled to one side
  8. #8 Re: zzp stage 2 axels
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Ive used stock axles for years. Once I started putting down real power I switched.
    Since 2012 Ive been running ZZP Stg2 axles.
    One thing I RECOMMEND is that you take off the large stock clamps on the boots and use hose clamps. This way they don't come loose and leak grease all over the ppalce
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  9. #9 Re: zzp stage 2 axels
    Doubt your actually at the power level where you need stage 2 axles.. just grab some new or remanuf from Napa or O'Reilly and spend the money on something else.
    04 Comp G.
  10. #10 Re: zzp stage 2 axels
    Buffalo
    Dee. Don't put the axles before the engine. You gotta build your car before you can worry about thinks breaking !
  11. #11 Re: zzp stage 2 axels
    Kansas City
    From what I was told Zzp stage 2 axles are basically what O'Reilly sells anyways.
  12. #12 Re: zzp stage 2 axels
    Mercer, Pa
    Do you really need an axle or are you upgrading without a failure?
    I've been running stock axles for 10 years on 3 different cars. Don't touch them till they break or arena problem.
  13. #13 Re: zzp stage 2 axels
    Jul 2012
    North Philly
    Yeah zzp stage 2 axles are stock GM axles.
    And yes my axels are both shot.
  14. #14 Re: zzp stage 2 axels
    SWPA
    So they are stock axles and ZZP sells them as "stage 2?"
    L
    O
    L
  15. #15 Re: zzp stage 2 axels
    hangover park IL
    we've had 50-75k stock 08 impala junkyard axles (with the OE 148k HD diff tulip swapped onto the right one) to 150 mph several times and have handled 600whp/575ftlbs of Tq through 26x11 et streets with plenty of slip and hook situations.
    i only swapped out the OEms cause we wiped the inboard clamps off during a hard tire shake (you could see the clamp marks on the subframe) the outers were getting pretty loose and i found a pair easy to remove from a rear end wrecked car.
    i have reused clamps on it with reduced grease quantity (you honestly dont need a pint of grease) and it still has not leaked or thrown the boot.
    ive had the trans apart 7 times for 2 converters, and a broken input shaft.
    dont worry about the axles
  16. #16 Re: zzp stage 2 axels
    hangover park IL
    i would give anything for the only breakable part to be the axles.
    i can swap those out in 15 minutes
  17. #17 Re: zzp stage 2 axels
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    Go get any parts store new replacements and be done with it. Most stores around me don't even sell remans anymore. Replace the axle seals while you are at it so that you don't have to pull the axles again for that down the road.
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  18. #18 Re: zzp stage 2 axels
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Do mine then haha
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  1. What aftermarket brand cv axels do you guys run?
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 09-28-2015, 12:01 AM
  2. CV axels
    By Nighthwk12 in forum General Tech Discussion
    Last Post: 09-20-2013, 07:29 AM
  3. Intense turbo cam, stage 1 or stage 2!
    By SharkBite in forum Wanted To Buy - Parts
    Last Post: 02-21-2013, 03:40 PM
  4. ZZP Stage II kit - Yay/nay?
    By acammer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2010, 10:45 AM
  5. Tired of IT - CV Boots/Axels
    By japslpr in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2008, 12:20 PM
