Thread: 2005 GTP best struts?
Results 1 to 6 of 6
  1. #1 2005 GTP best struts?
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    I already have some Eiback springs, but need to find a good set of struts. I have been looking for a decent one and so far the only thing I have come up with is the KYB Excel-G's does anyone else have any recommendations or are these pretty much my only option?? TIA
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: 2005 GTP best struts?
    SWPA
    Lowering springs are going to be harder on any OEM style strut. That being said from reading around here the KYB's seem to be the preferred struts for lowering springs. Probably AGX over the Excel G though.
  3. #3 Re: 2005 GTP best struts?
    Mar 2015
    Appleton, WI
    Can AGX's be used? I thought I read somewhere 04+ can only use the Excel's
  4. #4 Re: 2005 GTP best struts?
    SWPA
    04-05 have a different sway bar set up that attaches to the strut, but you can switch to the control arm and end links from 97-03 or 06-08 and use them.
  5. #5 Re: 2005 GTP best struts?
    This
    And
    A great excuse to get the Dorman (solid) swarbar
    04 Comp G.
  6. #6 Re: 2005 GTP best struts?
    Mar 2015
    Appleton, WI
    okay good to know, thanks !
  1. struts equal to GM konis struts
    By Dee23 in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2015, 02:47 AM
  2. replacement drop in struts for 2005 grand prix gtp comp g
    By Linebacker in forum General Tech Discussion
    Last Post: 03-15-2015, 08:43 AM
  3. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
