Thread: fbody upgrade making noise
Results 1 to 13 of 13
  1. #1 fbody upgrade making noise
    Feb 2015
    california
    Ok so on day 5 of this upgrade have fbody calipers hawk 5.0 pads and drilled slotted R1 concepts rotors. Getting a repetitious squeak noise while in drive not braking and son louder rubbing type noises on turns. Any ideas retaining clips? Grease? Bearings? How can I fix this?
  2. #2 Re: fbody upgrade making noise
    you bent the dust shield, its rubbing the rotor on the inside. well, chances are lol
  3. #3 Re: fbody upgrade making noise
    Feb 2015
    california
    Pretty sure I dont have a dust shield. Atleast not on front.
  4. #4 Re: fbody upgrade making noise
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by silenthaven View Post
    You do..it's a small ball joint shied on the lower part of control arm area
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: fbody upgrade making noise
    Most people take the wheel off and have a look themselves.
    We can't use our super powers to see what you did.
  6. #6 Re: fbody upgrade making noise
    Montgomery, IL
    20bucks it's the pad retaining clips, or the ball joint dust cover hitting rotor..you can bend that back without even taking wheel off..
  7. #7 Re: fbody upgrade making noise
    Nov 2011
    NY
    Retaining clips happens a lot. You'll need to take wheel, rotor off and take a look. See rub or wear marks on edge of clip nearest rotor. Look everything over good at each stage of disassembly.
  8. #8 Re: fbody upgrade making noise
    Feb 2015
    california
    If its the clip how do I fix that?
  9. #9 Re: fbody upgrade making noise
    Nov 2012
    Madison
    Reshape it so it doesn't hit the rotor. Make it snug in the bracket.
    Check both sides for clearance after you put the pads back in, then slide the caliper over.
    Sucks yes, but taking the pads out is about the only way to be sure.
  10. #10 Re: fbody upgrade making noise
    Dec 2013
    Enfield
    That dust shield can just be bent back a little , or cut right off. If its a hardware issue I recommend Carlson hardware, they are far superior to anything you get with the pads and really work well in taking away noise as they are coated. They car be found on Rockauto, although you probably have to buy for what the brakes came on .
  11. #11 Re: fbody upgrade making noise
    at what point will you jack the car up and spin the wheel? listen for the sounds....... look at the rotor for the rub mark......come on, get with it.
  12. #12 Re: fbody upgrade making noise
    Montgomery, IL
    Quote Originally Posted by ScottyDoggs View Post
    Was thinking the same thing..lol
  13. #13 Re: fbody upgrade making noise
    SWPA
    Hey guys my car is making a noise. Can you help me?
    LOL
  1. bolts on fbody brake upgrade
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2011, 04:16 PM
  2. Lowered car making noise
    By Amb4 in forum Tires & Wheels
    Last Post: 05-10-2010, 10:26 PM
  3. Fbody/C5 Brake Upgrade Help
    By arc in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 12:05 AM
  4. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
