Thread: Mysterious clunking sound and it's pi$$ing me off
Results 1 to 13 of 13
  1. #1 Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    As the title says I have a clunking noise that's aggravating me on my 04 Grand Prix. Every time I hit a bump (well most of the time really) there's a pretty pronounced clunk in the front end. I thought it was the control arm bushings, but nope (though the old control arms had pretty worn bushings in them). So then i did the sway bar ends, nope. So then I thought maybe it was the subframe bushings, again, nope (and again old ones were pretty bad). Only thing I can think of it might be is the upper strut mounts, but I don't want to keep throwing money/parts at this as eventually I'm going to want to spend money on something BESIDES repairing my car. Any help is greatly appreciated.
  2. #2 Re: Mysterious clunking sound and it's pi$$ing me off
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Check your steering gear bushing, try putting a pry bar in between the frame and rack to see if the bushing on the pasanger side is making the noise, it can be replaced and is a split design
    Team JB-Weld
  3. #3 Re: Mysterious clunking sound and it's pi$$ing me off
    GTP Level Member
    Aug 2012
    st louis park, MN
    Find your favorite bump and try lightly applying the brakes. If it goes away, it could be your pads hopping around in the caliper.
    I had this happening in my 2008 and it was EXTREMELY annoying!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  4. #4 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    It's not the brakes. Tried hitting the brakes on about 30 bumps on the drive home from work and the sound never changed. Though I'm sure the traffic behind me was thoroughly confused, lol. I'll have to check the rack bushings this weekend. I've been working too much and it's dark by the time I get off otherwise I'd do it when I got home. Thanks for the suggestions.
  5. #5 Re: Mysterious clunking sound and it's pi$$ing me off
    GTP Level Member
    Aug 2012
    st louis park, MN
    Dang, thought maybe it could be an easy fix for you. One other easy thing to check is the emergency brake brake cable housing where it runs to the back calipers. Mine was bouncing around hitting one of the suspension linkages and made a horrendous rattle - zip tied it to something. Yours is more of a clunk but it might be worth checking.
    Good Luck.
  6. #6 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    Nah, it's definitely in the front end somewhere. That and it's a pretty loud clunk.
  7. #7 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    So, I've been paying closer attention to the noise and when it happens. Doesn't happen when I hit a straight line bump with both tires at the same time. Only happens when one side hits something but the other doesn't. So while I was getting fuel tonight I cranked the wheel to one side and looked at some things. I paid a buddy of mine to do the sway bar links after I did the control arms and apparently he didn't do the driver's side. Called him and his dumba$$ response was "I thought you just wanted the pass side done." I have dumb friends... So I just ordered another link (moog) set (he used a cheapo part too) and I'm doing them myself this time around. This is why I don't pay anyone to work on my stuff. Lesson learned...again.
  8. #8 Re: Mysterious clunking sound and it's pi$$ing me off
    Oct 2014
    portland oregon
    still could be a strut. try popping the hood and pushing the tire back and forth. if you can see the mount move in the engine bay then its bad. i had a similar clunk and that was the problem
  9. #9 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    Quote Originally Posted by wowitsfast View Post
    Really? Yeah, both of them move around when you move that wheel.
  10. #10 Re: Mysterious clunking sound and it's pi$$ing me off
    Banned
    Probably the sub-frame mounts. Check to make sure your diagonal braces are tight too
  11. #11 Re: Mysterious clunking sound and it's pi$$ing me off
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I have an 04 with a clunk in the rear only happens when i hit bump on one side ive replaced everything still clunks solution music louder lol
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  12. #12 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    Subframe mounts were already done.
  13. #13 Re: Mysterious clunking sound and it's pi$$ing me off
    Nov 2015
    Rockford
    So the clunking noise is gone finally. Sway bar end links were the culprit.
  1. Clunking sound when turning
    By lilmidge12 in forum Introductions/Noob Questions
    Last Post: 12-22-2013, 06:33 PM
  2. Rear Clunking sound - please help
    By JB122894 in forum Brakes/Suspension/Chassis
    Last Post: 11-05-2013, 05:23 PM
  3. 04 gtp clunking sound HELP!!!
    By 901GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2011, 01:48 PM
  4. Clunking Sound
    By mheslin1 in forum Brakes/Suspension/Chassis
    Last Post: 12-11-2011, 12:02 PM
  5. Clunking sound coming from driverside wheel well
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 08:01 AM
