Thread: Brake upgrades, from a mix of sources
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Brake upgrades, from a mix of sources
    Buffalo
    What info ? Mine? What I stated 3x? Lmfao
  2. #22 Re: Brake upgrades, from a mix of sources
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    Yes lol I'm at work so I can only check periodically. I have received the info I wanted to know. 00-05 Impala rotors, which are same as 01 Monte SS rotors and 01 F body rotors, so I just need the rest of the F body components to do a change over. I wanted to know about 06+ Impala stuff but if it isn't an easy swap, I can't do it. I'm on a budget lol
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  3. #23 Re: Brake upgrades, from a mix of sources
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I did 06 impala brakes everything for less then $200
    Sent from my SM-S820L using Tapatalk
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #24 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    That isn't too bad! I have rotors already for F body, brackets and calipers are gonna run me about $60 and I just need new pads that's why I'm going that route
  5. #25 Re: Brake upgrades, from a mix of sources
    Buffalo
    Rotors used? Can you re surface them before using new pads?
  6. #26 Re: Brake upgrades, from a mix of sources
    Feb 2013
    Missouri
    Remember you'll need sleeves or drill\tap the caliper bracket if you got the F-body route.
  7. #27 Re: Brake upgrades, from a mix of sources
    Buffalo
    Already posted that info ... Can't force - feed anyone
  8. #28 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    Quote Originally Posted by Crazyguy03 View Post
    They are used, currently on my car lol I will either resurface or get new ones. They aren't too bad so I may just resurface.
  9. #29 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    As to the sleeving/drilling. I know some of you don't like ZZP but I don't have a ton of tools so if a solution exists that's easier than drilling myself, I'm gonna go that route. ZZP sells a bolt kit that is for swapping to F body brakes, no drilling/sleeving required
  10. #30 Re: Brake upgrades, from a mix of sources
    Fbody
    4 12mm fbody caliper bracket bolts (12x1.75x40mm)
    Mcmaster 6679k16
    you can buy brand new calipers with bracket from advance auto using discount codes for $30 a side. Give them your old calipers as a core
    Did you read what bob posted
    04 Comp G.
  11. #31 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    Yea but my understanding is that you then need to drill the brackets to fit stock mounting points
  12. #32 Re: Brake upgrades, from a mix of sources
    You can either drill/tap the bracket to correct size or use sleeves to make up the difference.
    http://www.grandprixforums.net/threa...d-Brake-Thread
    Read
    04 Comp G.
  13. #33 Re: Brake upgrades, from a mix of sources
    Feb 2013
    Missouri
    You can buy the sleeves from McMasterCarr for pretty cheap. Don't get anything from ZZP unless you like getting screwed. Read that thread Red posted and it'll give you all the info you need.
  14. #34 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    Just got the calipers/brackets, they are in pretty good condition! Just gotta clean em up a bit. Can you post a link to those sleeves if you get a chance?
  15. #35 Re: Brake upgrades, from a mix of sources
    http://www.regalgs.org/topic/54303-f...brake-upgrade/ has all the info in it for the sleeves, cost like 12 bucks. im running them for like 4 years now, no issues at all.
  16. #36 Re: Brake upgrades, from a mix of sources
    Buffalo
  17. #37 Re: Brake upgrades, from a mix of sources
    Feb 2014
    Rhode Island
    I'm gonna follow that to a T! Question: do I need the SS brake lines? Or will resuing stock work?
  18. #38 Re: Brake upgrades, from a mix of sources
    Canada
    I did the Impala conversion brake on my 08 Grand Prix. The only problem, you cannot put adhesive wheel weights in the inside of the wheels, the calipers is too big and rub on the weights. I hate the look of clip-on wheel weight... I'm looking now for thin wheel weight.
  1. best factory suspension and brake upgrades for w body
    By usetaboost in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2014, 10:26 PM
  2. Need some help determining sources of noise
    By nik12937 in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2012, 03:16 PM
  3. A new place for W-body suspension and brake upgrades!?!? Coilovers??!!
    By copgtp in forum General Grand Prix Discussion
    Last Post: 03-23-2012, 08:58 AM
  4. 2006 GP Brake upgrades
    By BrianC636 in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2009, 07:16 PM
  5. Rear Brake upgrades?
    By TMC in forum Off Topic Discussion
    Last Post: 05-08-2009, 08:06 AM
