I have done searches on here trying to get info on how to remove Eibach lowering springs. Can't find any info on this question:
When I go to remove the Eibach springs, do I need to use spring compressors?
I know that spring compressors are necessary for the stock springs. But I recall someone once saying that for any lowering spring, you do not need to use spring compressors to remove the top nut from the assembly.
